Rear window problems on 1990 4Runner
Old May 31, 2006 | 08:50 AM
surferfrank's Avatar
Help! I know someone out there has fixed this problem....
My 90 4runner rear window doesn't go down when using the key or the console switch. It works occasionally only after repeated pressing of the console switch. It seems very random when it does work. When it does work, it goes up fine. I can hear the relay in the up and down positions. I tried looking for the ground in the gate, but I cannot find it. ANy suggestions?
Old May 31, 2006 | 08:57 AM
snap-on's Avatar
id take the access pannel off and take a look inside to see if there are any obious problems.
Old May 31, 2006 | 09:22 AM
rdharper's Avatar
Rear Window logic
It would be helpful to have the wiring logic/diagram.
Apparently the motor, when it is activtated, seems strong. Still possibly a motor problem, but not likely.
Since both switches pretty much behave the same way, that leaves the relay and any lock-out logic. Seems to me that there must be logic to say: Ignore the switches, I'm in the tailgate down position...etc. That switch/sensor may be working intermittently.
Old May 31, 2006 | 09:45 AM
snap-on's Avatar
very well, good luck
large version
http://www.snjschmidt.com/wiring/rea...wer_window.jpg
page 2
http://www.snjschmidt.com/wiring/rea...r_window_2.jpg
page 3
http://www.snjschmidt.com/wiring/rea...r_window_3.jpg
Old May 31, 2006 | 11:03 AM
rdharper's Avatar
Nice post. That should help surfer to figure out his problem.
Based on your diagrams, there are several things that can lock out the window up/down switches. At a guess, the wiper is probably the most likely. The logic is that if the wiper is not fully retracted, you can't move the window. Pretty logical.. Since the wiper gets the most use, I'd check that that switch is fully closed. Since its intermittent, you could try to seat the wiper while closing the key window switch.
Same with door closed/open logic.
Somewhere there is a micro-switch which says..."don't move that window".
Old May 31, 2006 | 03:04 PM
reply to all help
Thanks for all the quick responses... I scoured the forum looking for an easy fix, but I may have to troubleshoot further. I'll look into the lock out switch direction. The wiring diagram looks kind of complicated to me. I don't really know where all these switches are located.
In one of the responses, do you think the relay has anything to do with the problem? The motor seems strong enough when it is working. The relay clicks in up and down positions. I found the relay on the rear drivers side.
Old Jun 1, 2006 | 04:59 PM
leebee's Avatar
so, has anyone figured out a solution to this dilema? i replaced my old motor because the gear was worn out, the newer motor worked great until tuesday. i put the window down on the way home from work, closed it before going in the house and come wednesday, the window does not open.
i really would like to know what to do to fix this, wiring is another language for me. ive read up on rogers site but i have no idea where to go from here. a tried and tested fix for this would be greatly appreciated.
lee
Old Jun 1, 2006 | 11:23 PM
8422r4Runner's Avatar
On my 84 the back window does not work unless I lean hard with my left hand in the upper left corner of the gate. Doing that completes a circuit that tells the rig the back door is shut. Works great.
Worth trying.
Old Jun 2, 2006 | 09:36 AM
rear window problems
Here's an update on my rear window problem.
I opened the rear gate hatch and inspected all the connections. They looked good. I sprayed some electrical connection cleaner on one "relay"( it's a small black box with a spring arm and wheel on one of the armatures). I locked out both sides of the gate and the window worked both up and down everytime I keyed the switch. After I put everything back together, the window started to malfunction again. Only in the down direction. Once again, it takes numerous attempts with the console switch to bring the window down. It seems extremely random as if some contact is barely touching somewhere. I'm going to try the contact cleaner again to see if it does some good.
Hope this update helps my fellow Yota mates. Maybe you guys will have some luck.
Old Aug 15, 2006 | 05:51 PM
bigmuddy's Avatar
rear window problem
Hi I have a 1990 4 runner that works quite well, except the rear window does not want to go down with the key. It will go up with the key and it will go both up and down using the switch on the console. I have assumed it must be the keyed switch that has malfunctioned but after doing some reading here, I am not so sure. Anybody care to take a stab at this?
thanks Ben
By the way, my 90 runner only has 24k on the motor
Old Aug 15, 2006 | 05:58 PM
window
check the links to the same problem... I found the problem in the relays. See the diagram which one it is or replace all four. Radio Shack sells them for about 5 dollars. I tried everything and the relay replacement fixed it.
Old Aug 15, 2006 | 06:03 PM
here's the link to the relay fix. I had the same problem. It is the relay for sure.
https://www.yotatech.com/forums/f116/94-rnnr-rr-windw-problms-help-82330/
good luck
Old Aug 15, 2006 | 06:04 PM
bigmuddy's Avatar
Thanks surferfrank! I was dreading buying an 89 dollar switch from Toyota! Yeah you are probably right, I can here the relay click when going up but not when going down.
thanks a Bunch!
Ben
Old Apr 16, 2013 | 06:13 PM
JoelEThomas's Avatar
I have a 90' 4runner with a 22re and Manual. I was re-wiring the back window Modulator and like an idiot I didn't disconnect the battery. Some wiring touched and sparked. Now it won't start. Checked all my fuses they are good. Checked the Alternator, Starter, Battery and they are good too. Even check my starter relay and that is good. The last thing I can think it could be is the ignition switch, but it clicks when I try to start it. So doubt it that. When I turn the key to start the volts meter go way down. Please Help!!!
Old Apr 16, 2013 | 08:01 PM
main fuse
Old Apr 16, 2013 | 08:07 PM
Originally Posted by Richard
main fuse
If you are referring to the black 80amp fuse in the fuse box I already checked it. Can't think of any another main fuse. If this was blown nothing would come on at all. It still push starts.
Old Apr 17, 2013 | 04:11 PM
92Yoda's Avatar
Ive had rear window problems as long as ive had my mine(2years), ive replaced the circuit board twice that was a temp fix, i replaced the relays on both circuit boards twice that was a temp fix, i took the console switch apart that didnt do anything. Then yesterday i went and picked up a used camry drivers side motor(exact same motor, different plug, 2 minute modification) and bam windows fixed and reliable again, its also abit faster. I always thought my motor was fine because sometimes it worked, i figured if it works sometimes the motor is still fine and the relays are causing the problem but that wasnt so. Go pick up a used 87-90 drivers side window motor and fix it!! Takes 5 mins to replace motor and plug. Btw my motor was $40 with a regulator but i dont need the regulator
Old Jul 29, 2013 | 06:15 AM
DRM's Avatar
DRM
I picked up a 1990 4Runner a few months back and the rear window is dead - switch or key. Should I assume motor? I've never been into the 90+ rear gate, so not sure what to expect. Guess I get to crawl back there and pull the trim cover and see what I can see.
Old Nov 3, 2013 | 07:56 PM
clok's Avatar
does anybody know if these 4 relays are found in the tailgate behind the rear panel ? and are they easy to get to ? thanks.
Old Nov 3, 2013 | 07:58 PM
clok's Avatar
thanks Ben
this is the same problem i'm having.
