rear tire rub on frame!! 2nd gen 4runner
Old Nov 17, 2010 | 09:30 PM
drkblu4runner's Avatar
Lightbulb rear tire rub on frame!! 2nd gen 4runner
rear has 4ish in lift (got truck lifted) with pro comp shocks?
i think i just need wheel spacers, but if u look at pics there is shill 4in of shock/bumpstop travel left. does any one els have this problem.
added 1/4wheel spacer shims, that helped.....KINDA....
ya like my special built flex ramp haha
Old Nov 17, 2010 | 09:37 PM
dropzone's Avatar
Fossilized
looks pretty common to me, especially with that B/S on your rims.
might as well remove that mudflap now,the tire will do it for you...
Old Nov 17, 2010 | 09:59 PM
YES thats my axle hanging from the brake line!! already ordered tacoma brake line thats longer; i think. the specs said it was 21in
Old Nov 18, 2010 | 04:27 AM
waskillywabbit's Avatar
New rims, skinnier tires and/or wheel spacers.
Looks good
:wabbit2:
Old Nov 18, 2010 | 07:55 AM
rattlewagon's Avatar
my 35s do that. I just let it happen. meh.
Old Nov 18, 2010 | 08:02 AM
dropzone's Avatar
Fossilized
B/S= backspacing
rlordjr's Avatar
Sort of hijacking this thread for a related question. My 33's rub just a bit on the bottom of the inside front fenders. Already took off the mudflaps.
Rather than let the rubbing wear more room for them, I'd like to ease that section of the inner fender a bit. Anybody got any tricks/tips for that? My normal method would be a planishing head in an air chisel to "delicately" pound that stuff out of the way.
Last edited by dropzone; Nov 19, 2010 at 06:21 PM. Reason: censor pick up on a no no
Old Nov 18, 2010 | 08:10 AM
cootees's Avatar
Not much you can do about it unless you change the wheels.
Old Nov 18, 2010 | 05:05 PM
for the front i got a big hammer and a cut off wheel took a little off the top. i have bjs tho...
will 2in spacers fix it or will it still rub?????
Old Nov 19, 2010 | 08:21 AM
cootees's Avatar
Wheel spacers will band aid it but not fix the issue. 2" spacers will more than likely work, you probably don't even need that much. Really, I would just get some new (used wheels) and be done with it.
I have 37x12.50 with 2" bs wheels and I don't even come close to rubbing the frame.
Jake28296
Jun 27, 2015 07:24 AM
marcusSRG
Jun 27, 2015 07:13 AM
Niameyrider
Jun 25, 2015 05:50 AM
infinityisfive
Jun 16, 2015 06:51 PM
westbound
Jun 7, 2002 03:30 PM
