Rear mount turbo 3vze finished
Old Aug 22, 2014 | 04:31 AM
  #81
Terrys87's Avatar
Enjoyed reading your project. I like seeing thinking out of the box. I see you have some time and work involved. Great job!!!
Old Aug 22, 2014 | 12:07 PM
  #82
Turbopickup24's Avatar
Originally Posted by vasinvictor
http://www.ebay.com/itm/NEW-Electric-Oil-Scavenge-Pump-for-Remote-Low-Rear-Mount-Turbo-Return-Line-12v-/280782665954?pt=Vintage_Car_Truck_Parts_Accessories&hash=item415ff378e2&vxp=mtr
Works well, a little noisy, but nature of the beast...
Methanol works very very well for fueling actually. I'm spraying 22gph from 2 nozzles at 14lb boost. AFRs are high 11s and touch on 12.1 at redline. Stock EVERYTHING. I'm using a very nice and expensive progressive controller with 2 failsafes. You could use a cheap universal kit, a 14gph nozzle on a 1psi hobbs switch. You can set your methanol tank up with a float switch, so when it's low you can trigger a http://www.ebay.com/itm/MAC-Boost-solenoid-valve-BCS-35A-AAA-DDBA-1BA-compatible-with-most-ECUs-EMS-PWM-/331006948808?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d118d35c8&vxp=mtr to cut to wastegate spring pressure. That's how mine is set up and I have a 2lb wastegate spring so when I'm out of meth, or somethign goes wrong, boost cuts to 2psi instantly, thus saving motor.
I was exspecting a differnt pump i seen that one i was looking for one that specifcaly said (Boost Doctor) like youill look into
Old May 14, 2015 | 11:43 PM
  #83
dirtydeeds's Avatar
hey, to the OP, I know I'm late to this party, but I have a solution to your closed loop enrichment problem.
https://splitsec.com/product/lsc1-00...chment-module/
I can't admit as to how I know this, but I know a guy using it and it works fantastic. And the owner of Split Second will walk ya thru the install. he will also give you wiring diagrams and help your install. Super simple, cut the signal wire of the o2 sensors and put in the enricher.
I real quickly show how I used it in this thread:
http://www.tundrasolutions.com/forum...l-tune-thread/
jon.r
Jul 11, 2015 03:34 PM
smiley52
Jul 11, 2015 05:16 AM
skoti89
Jul 8, 2015 12:05 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
karbin
Jul 5, 2015 11:37 PM
