rear axle bearing tool (homemade)
Old Nov 22, 2021 | 07:02 PM
Shake rattle n roll's Avatar
Anyone got some details they can share with me ?
my hunting rig 91 4 runner has a bad noize , I figure it is rear wheel bearings.
I have an old housing , but not sure what to do with it for a tool.
thank you kindly
Old Nov 22, 2021 | 07:51 PM
BigBluePile's Avatar
I just Googled this...
Old Nov 22, 2021 | 10:11 PM
emsvitil's Avatar
The last time I replaced toyota axle bearings (although it wasn't a truck), I just used the drum as a slide hammer to get the axle out of the housing (leaving everything attached to the axle)..........
Old Nov 23, 2021 | 04:38 AM
clearly you dont understand what I asked.
I had both axles out of my truck , and 3 out of my parts trucks yesterday.
I was told you need a special tool to remove and install the bearing from the backing plate.
the tool a guy mentioned , was made from an old housing
Old Nov 23, 2021 | 05:00 AM
https://youtu.be/bdMlhDMqgJI
thank you .
that was helpful
Old Nov 23, 2021 | 05:24 AM
emsvitil's Avatar
When did it, the backing plate stayed with the axle housing.
Axle came out with bearings. All that was needed was press and bearing separator.
What year truck?
Old Nov 23, 2021 | 05:38 AM
akwheeler's Avatar
Check out my build thread and you'll see what I did for pulling/installing rear wheel bearings, post #7 & 8 if this link doesn't work:
https://www.yotatech.com/forums/f199...l#post52320417
Old Nov 23, 2021 | 06:00 AM
Thank you kindly :-)
I am out hunting , And it is just not the same without my 4 runner
Old Nov 23, 2021 | 06:25 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I did that method that emsvitil is talking about, except I cut the bearing retainer off first. with that out of the way using the drop method works well. Even in the FSM, using the oem tool you were supposed to get the retainer off first.
Old Nov 23, 2021 | 07:46 AM
rattlewagon's Avatar
Heres a super handy page.
http://www.4x4wire.com/toyota/mainte...wheel_bearing/
leid
Aug 30, 2018 01:27 PM
owbro
Jun 23, 2013 03:26 PM
dropzone
Sep 17, 2011 09:18 PM
Ilovemountains
Aug 10, 2008 06:55 AM
lauried
Sep 15, 2007 09:11 PM
