Rateling noise in my 89 v6
Old Jan 3, 2007 | 05:57 PM
8yota9's Avatar
there is a strange noise comming from some were under the hood i think. sounds like a empty coke can in my moter eney ideas on what it could be?
Old Jan 3, 2007 | 08:23 PM
yota_krazy's Avatar
maybe an exhuast leak? Try checking your engine oil level too. A good bet for noises like this would be to get a stethescope and probe around different areas of the eingine compartment until you find the source of the noise. Good luck!
Old Jan 3, 2007 | 11:39 PM
drew303's Avatar
Does it do it at a certain RPM, increase with an increase in RPM?
Could be the fan hitting it's shroud or an exhaust leak or something worse. Who knows need more details.
I know from experience a leak at the exhaust manifold can sound like a rattle.
drew303's Avatar
oh, could also be a light rattling
Old Jan 4, 2007 | 08:13 AM
8yota9's Avatar
it sounds more like it is comming from the pasengers side down by the manifold it dose it wen ideling and wen gently taking foot off cluch wen ingaging to first also wen cold f you hit the gas it bogs down verry strange maks me reel nervis cuz shes my baby and i put all i got into her
Old Jan 5, 2007 | 07:30 AM
8yota9's Avatar
eneyone???? help please
Old Jan 5, 2007 | 08:40 AM
milowilli's Avatar
Sounds like the reed valve..they can make a racket when bad..it is on the passenger side near the firewall..you can pull off the vacuum hose on the valve to see if the noise stops. The hose that goes from the air filter to the metal pipe on top of the manifold can be removed too to see if the noise goes away( the bigger of the 2 hoses they are together..NOT THE BIG FAT AIR INTAKE HOSE).If it does replace or bypass the valve...hope this is your problem.
Old Jan 5, 2007 | 01:27 PM
The Toe Cutter's Avatar
This wouldn't explain the bogging down, but my '94 V6 makes a similiar type noise when its cold.
Sounds like a bad bearing.....I find out when I turn ON the A/C the noise goes away. Assuming its a bearing inside the A/C compressor, however I haven't pursued fixing it do to costs & it only does it in winter months.
Just my $.02
Old Jan 6, 2007 | 04:46 PM
8yota9's Avatar
well i have a new exaust from the down pipe back so i dono if it is a leak in it but i did try putting the ac on and it went away but it also makes it in 4th wen ur doin like 35v same problum the ac??? also there is a ticking noise that gose with the rpm but lessens in hier reves and gears eney clue???
Old Jan 7, 2007 | 04:39 PM
8yota9's Avatar
Question
Dose this help eneyone with a answer cuz i have no clue
Old Jan 7, 2007 | 05:04 PM
Weird, I have a ticking noise when its cold (sounds like speedo cable), but I looked behind dash & I have electronic speedo unit I guess. My ticking noise happens regardless of engine RPM so I think its something in the front end or dash.
If it ALWAYS goes away when A/C is on, then I would dig into that & see if its worth it replace bearing inside compressor. I think when I looked into it, the part/labor was almost not worth it.
Old Jan 10, 2007 | 03:51 PM
8yota9's Avatar
could the ticking noise be from the valves and it also rattles when in hi gears like 4th at low speeds still the ac yo think
Old Jan 12, 2007 | 09:56 PM
benwahballs's Avatar
i had what sounded like a very faint rattle at certain times when I first bought my 89 v6 5spd. It was a bad bearing if I recall, I believe the timing belt idler pulley bearing.
Have you tried yota krazys stethescope idea? Have someone adjust throttle/play with clutch and try and pinpoint an area where it's coming from.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
