Random Green wire with black stripe?
Old Feb 21, 2010 | 08:09 AM
ramrugby09's Avatar
Ok I have an 86 4runner with 22re and auto tranny. I have found a random wire with no home. it comes out from under the plenum coming from the same section of harness as the fuel injectors and such. Anybody have a clue where it goes? Random green wire with black stripe all alone?
Old Feb 21, 2010 | 08:35 AM
iamsuperbleeder's Avatar
the only thing down there is the oil pressure sensor and the knock sensor
is your oil pressure gauge working?
Old Feb 21, 2010 | 09:26 AM
ramrugby09's Avatar
Well i don't have an oil gauge. Just an oil light and as far as I know it works. Isn't the the oil temp sender near the oil filter? If thats the sender it has a wire connected to it. The knock sensor is in between the valve cover and the plenum right? If so then it also has a wire connected to it...?
Old Feb 21, 2010 | 09:51 AM
DJ99's Avatar
Do you or have you had AC on this truck? It looks like it could be the AC clutch solenoid wire. It's in the right general area. Just a guess.
Old Feb 21, 2010 | 09:57 AM
abecedarian's Avatar
Just looked over a wiring diagram for 86 and it shows the green/black wire going to a simple water temperature switch (cold-grn/blk open, warms up- grn/blk grounded) but does not call out the function of the switch.
Old Feb 21, 2010 | 01:46 PM
ramrugby09's Avatar
hmmm not too sure where that switch would be...
Old Feb 21, 2010 | 04:12 PM
stormin94's Avatar
Does it run/drive fine, and everything works?
Old Feb 21, 2010 | 06:38 PM
Chuck Manners's Avatar
chuck
i have a 90 toy pickup regular cab 22re 5 speed. there are several unused plugs under the hood. toyota must have used the same wireing harness for muitlple models. some plugs are simply not used for some models
Old Feb 22, 2010 | 04:38 AM
DanStew's Avatar
LOL I was looking at my engine bay yesterday and found thatr same exact wire in the same shape. My truck runs. also not sure of the wire.
Old Feb 22, 2010 | 12:15 PM
ramrugby09's Avatar
yeah my truck runs well but i hate thinking that ive got something not working that should be
Old Feb 22, 2010 | 11:52 PM
stormin94's Avatar
I wouldn't be too worried about it. Who knows, you might hook it up and cause a problem. lol
Old Feb 23, 2010 | 12:01 AM
toyota4x4907's Avatar
Toyota did use the same harness with all the plugs and what not regardless of options. I'm sure if you look around more you will find more "useless" plugs.
Old Feb 23, 2010 | 12:51 AM
stormin94's Avatar
Like my center console rear heater harness.....
I've seen a couple different vehicles with roll up windows that had the wiring harness inside the door for power windows. Seemed kinda pointless to me, like why wouldn't they just finish the job, and put the motor and switch in? lol
Old Feb 23, 2010 | 05:26 AM
5.04runner's Avatar
mine has the same green and black wire hanging out in the same spot not connected to anything. it runs great so i have no clue what its for.
80Truck
Oct 12, 2025 07:25 PM
MO transplant
Apr 23, 2023 11:58 AM
_Nicco_
Aug 28, 2015 07:26 PM
Johntom240
7
Jul 13, 2015 12:18 AM
88runnergomas
Jul 9, 2015 01:12 PM
