Quieting the Tailgate Hinges
Old Nov 21, 2008 | 10:59 PM
chrisbnaz's Avatar
Is there any way that you guys have come up with to keep the tailgate hinges from rattling around? Everytime I go over a bump, even the slightest of bumps and they rattle like crazy. It's loud and annoying as hell, they sound like they're banging back and forth on the tailgate. I glanced at them real quick and didn't see any obvious way of tightening them or anything like that...When the tailgate is down, they're not lose or anything...I can't be the only one with this annoying problem..
Old Nov 22, 2008 | 12:00 AM
Robert m's Avatar
i covered mine in heat shrink that you use on wires and havent had a problem since.
Old Nov 22, 2008 | 12:03 AM
chrisbnaz's Avatar
Interesting, maybe its the fact that it's 2am, but I'm trying to picture how that would be effective. That would have to be some big heat shrink to cover the hinges.
Old Nov 22, 2008 | 04:17 AM
874runnersr5's Avatar
i guess toyota sells these plastic washers, i made a thread a while ago about the same thing lol
Old Nov 22, 2008 | 06:29 AM
87AzRunner's Avatar
if you wanted to cheap out i bet you could
unbolt them cut up an old bike tube an slide it over
them, the rubber would cut the sound down i would think.
idk, something i just thought right now.
i wrapped mine in the foam you put on conduit and stuff.
it falls off now and then, but its worth not hearing that
crazy rattle
Old Nov 22, 2008 | 08:20 AM
iamsuperbleeder's Avatar
mine squeak abnoxiously loud when putting the tail-gate up, but I don't have any rattling issues
Old Nov 22, 2008 | 08:31 AM
4Crawler's Avatar
Yep, I picked up a set of those to replace the broken broken remnants of the stock ones and no more noise since then. And they are more than washers, they have little springy tabs on them them wedge the two pieces of metal tight so they can't rattle. Prior to that, I had a little luck with brushing on several coats of the poly tool grip paint to build up a thickness of the soft material.
Old Nov 22, 2008 | 02:25 PM
i guess you went to toyota? part # by any chance?
Old Nov 22, 2008 | 02:50 PM
4Crawler's Avatar
Yes, went to a Toyota parts counter with teh VIN off my 4Runner and asked for a pair of anti-rattle clips for the tailgate supports. Did not save the p/n as that was about 8 years ago.
Old Nov 22, 2008 | 04:08 PM
oh wicked, thanks again 4crawler!!!!
Old Nov 22, 2008 | 08:17 PM
Green93's Avatar
I feel your pain. I guess this is a common problem, I just bought a set of those plastic clips myself. I think they were about $4.00 for the pair. Probably the best $4.00 I've spent on my truck. I hated those angled speed bumps the most. All 4 tires go over the bump at different times...and the hinges are rattling the whole time.
Jason
Old Nov 22, 2008 | 08:59 PM
hahaha yeah, every bump or side movement i get to hear the clanking..
il probley go order them tomorrow, and while im there order my shifter seat bushing
Old Nov 22, 2008 | 10:11 PM
just a 22re's Avatar
so thats what that rattle is man i could never finger out what it was sweet time to do that on both my runners
Old Nov 24, 2008 | 10:58 AM
space-junk's Avatar
okay, so mine doesnt rattle from the hinges, but theres a lil round metal bar that slides underneath my runner that squeeks like crazy when i open it up...
Old Nov 24, 2008 | 11:01 AM
4Crawler's Avatar
That is the torsion bar that makes it easier to raise and lower the tailgate. Add a little grease to the moving parts to silence them.
Old Nov 24, 2008 | 08:55 PM
ah so i went to the stealership to order my shifter seat bushing and while i was there i looked into the clips
but they didnt have any idea, she printed me off a diagram but the only part was some thing that didnt make sense, i think it was 4$ thoe... so could it be it?
Old Nov 24, 2008 | 09:40 PM
Green93's Avatar
The name didn't make sense to me either at first. Hinge stopper or something like that. The clips are mounted to the bed...so when you look at the diagram you should be able to figure it out. Also, when I got mine the part # was for a pair of them. That might help to find the right part as well. I just threw away all my little Toyota baggies with the part #'s on them.
Jason
Old Nov 24, 2008 | 09:45 PM
Green93's Avatar
Ok, just went to the garage and looked through my pile of receipts. According to this they were $4.88 each, so make sure you are getting 2. It's called a stopper and the part# on my invoice is 65778-89105.
Jason
Old Nov 25, 2008 | 07:08 AM
AH!
so it was those, shoot!
thanks alot green!!
I8URSVT
Mar 2, 2021 06:23 AM
matmattmatthew
10
Feb 9, 2021 04:15 PM
justdifferentials
14
Jun 11, 2017 08:36 PM
MaK92-4RnR
Oct 28, 2015 02:45 PM
gp66
Sep 14, 2015 12:10 AM
