Quick, Easy, Painless 3vze Intake Plenum and Upper Engine Cleaning and TuneUp
Old Feb 27, 2014 | 02:56 AM
Cruz muench's Avatar
I've never used sea-foam. Is it really that good?
Old Feb 27, 2014 | 08:33 AM
Gamefreakgc's Avatar
Anyone in California have any luck purchasing Power Foam? I can't seem to find a vendor that will sell it.
Nvm, I found one
Old Feb 28, 2014 | 12:09 AM
RSR's Avatar
RSR
HC is hydrocarbons -- unburnt fuel. Cat might be going. Also look at your fuel injection and ignition components.
Assuming you're a V6, the flamethrowers introduce atomized fuel instead of stream resulting in better burn. Changing out spark plugs, wires, cap and rotor at least to start on ignition.
Also check all sensors on these and your AFM too. Wouldn't hurt to check all your temp sensors either.
Old Feb 28, 2014 | 04:37 AM
mylittlepony1's Avatar
I've tried this as well, with amazing results! I did not take pictures however
Old Feb 28, 2014 | 07:25 AM
  #25
Terrys87's Avatar
Great write up RSR.
It will cost more for a factory Toyota Catalytic Converter, but from what I have seen of the aftermarkets converters, they are cheaply made. As I understand it the ones in California have a tough time passing smog with an aftermarket converter. I have scrapped out 20 year old factory converters that were in better condition then a newer aftermarket.
Old Mar 1, 2014 | 07:59 PM
  #26
oeiak91's Avatar
I ran seafoam instead of amsoil followed your instructions to a T. It's freakin awesome how much better my throttle response is now and the rpms just climb wayyyy smoother!! Nice work man everyone should do this for an immediate jump in performance. Only thing that went wrong was my intake boot was sooo old and brittle when I tried to slide it over the spray hose and clamp it down my intake boot cracked on both sides. So I had to jerry rig it and electrical tape that hell out if it until I can get a new boot .
But man it really helped a lot! I can most definitly feel the increase in power.
Old Mar 1, 2014 | 08:16 PM
  #27
RSR's Avatar
RSR
Cheap chinese boots on amazon and elsewhere for $30. It's a quick fix. Also search ISR delete and consider going that route to move your intake up off your manifold.
While you're in there, open your throttle and look down it with a flash light. I think you'll see your plenum is full of carbon and then should do amsoil!
I look at it as Seafoam excels in cleaning the combustion chamber in your engine -- piston head, exhaust valves, seats, etc of carbon, but is less effective than Amsoil overall. Running Seafoam first cleans your combustion chamber for you. Then Amsoil does the final cleanup of your upper intake and anywhere else the seafoam missed.
Yes, it does make a tremendous difference. Equivalent for me to what I go by advancing timing to 12* btdc.
Old Mar 1, 2014 | 08:26 PM
  #28
oeiak91's Avatar
Cool! I'm gonna run the amsoil next then. I'll snap some photos when it's all apart again. I also been looking at a cold air intake mod instead of buying that boot. I think I gonna get a K&N and rig up a whole new pipe for my intake. I just picked up my 3vze a little while back and I'm just looking and cool mods and neat stuff I can do to help with performance.
Thx again!
Old Mar 1, 2014 | 08:34 PM
  #29
RSR's Avatar
RSR
Big NO to K&N. You want cold air, not the hot air in our engine compartments. Also, K&N's oil ruin our AFMs. And they aren't effective at filtering particulate, which creates add'l wear and tear throughout your engine.
See these threads for better ideas:
https://www.yotatech.com/forums/f116...or-mod-272014/
https://www.yotatech.com/forums/f116...-setup-272137/
https://www.yotatech.com/forums/f116...er-one-272657/
Old Mar 1, 2014 | 08:50 PM
  #30
oeiak91's Avatar
Lots of options. Wow man had no clue it's that easy! Well not easy but affordable doable yourselfable haha.. Any opinions on which one give best performance boost? And not overly noisy? I like cool sounding low rumble but not super loud like a rice rocket.,
Old Mar 1, 2014 | 08:51 PM
  #31
I agree, I had a modified intake that drew in engine bay air. Was great cold but in the summers and after running 10 min the power got sapped from the high temps. You want to pull hold air from outside the engine bay.
P.S. the holes in the frame trick works great
Old Mar 1, 2014 | 08:56 PM
  #32
oeiak91's Avatar
I'll add that if someone does before and after pics, I'd be stoked to see them as I just have memories... Again, the keys are a piping hot engine and plenum, and allowing time to soak (allowing the gases/foam to spend more time and to dissolve the crud in the upper intake instead of running straight through to the upper engine cylinders). And don't forget the final tuneup items to get the full benefit from your now clean and less restrictive plenum.
I'll take before and after pix when I run the amsoil.
Old Mar 3, 2014 | 07:24 AM
  #33
Just did it yesterday on a hot engine, seems like mine's already pretty clean since nothing really changed. A lot of smoke though!
I'm gonna try the engine flush next. I've run seafoam and MMO in my oil once before (made it really dirty!) so looking to clean it out even better. I'm trying to get my rig in as best of shape as possible since I will have to sell it in the near future.
Old Jun 18, 2014 | 09:09 AM
  #34
Just to follow up on this one,
My O2 sensor failed at 10k miles. I don't burn oil or coolant. The only thing I did different was the Powerfoam treatment. I knew this was a possibility going in but I had a spare and my engine's old so had nothing to lose really. When I pulled it out the forward edge was coated in carbon and a white film (the powerfoam, incidentally, is also white).
Just a heads up!
Old Jun 27, 2014 | 12:04 PM
  #35
StayFoolish22's Avatar
Is this a good heads up or bad. Planning on doing this once I get the truck drivable again. We are having real bad power issues.
Old Jun 29, 2014 | 05:50 PM
  #36
Bad, I suppose. Every cleaning chemical claims to be "O2 sensor safe" but this one is not. Just be prepared to change the sensor if you do this (which runs about $60) or swap in an old one instead while cleaning.
lledwod
Aug 30, 2016 01:03 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
