The quench on my 22R does not look good...
Old Oct 9, 2006 | 05:41 PM
Ando's Avatar
Angry The quench on my 22R does not look good...
I just got home with my short block and checked the quench to find, all the pistons under deck height! #1 was at -.006, #2 -.009, #3 -.009, and #4 -.009... What should I do? Do you think the machine shop will correct this for free? Or were they counting on me overlooking this? Thanks for your opinions.
Heres a check list of what the machine shop did:
overbord/honed +.020 (EB's pistions)
recondition rods
polished crankshaft
deck block
assemble engine
Old Oct 9, 2006 | 07:07 PM
AH64ID's Avatar
looks like they need to deck the block...
have you seen this?
http://www.4x4wire.com/forums/showfl...fpart=all&vc=1
Old Oct 10, 2006 | 05:33 PM
Ando's Avatar
Yah, I found Ted's right up very helpful. I actually have it printed out and next to my work space.
Old Oct 11, 2006 | 10:17 AM
suprathepeg's Avatar
What you need to do is have them deck it .006 to get them all as close as possible. I did that with my 3vze, it costs you a set of bearings though.
Old Oct 11, 2006 | 02:28 PM
dcg9381's Avatar
Why does it cost a set of bearings?
Old Oct 11, 2006 | 03:13 PM
AH64ID's Avatar
Was the head decked? Accoring to that ENGNBLDR article you want the head and block decked in .010 increments so you can fix the cam timing, unless you get an adjustible timing gear...
Old Oct 16, 2006 | 07:22 PM
Ando's Avatar
Yes the head was decked also, by how much I don't know? I think I will get a adjustible cam gear just to be safe. But I'm finding it real hard to justify spending 100 bucks to shave .009" off an already decked block ...
Old Oct 16, 2006 | 07:51 PM
Then leave it alone. There is only one way to get things where you want them and thats the machine shop. Decking to the point where the one or more piston sticks out above the block isn't a good idea though.
Old Oct 17, 2006 | 01:23 AM
AH64ID's Avatar
Thw quench on a 22RE is supposed to be up to .006" above the deck... take a look at that link a few posts up. You also want all the pistons to have the same quench for uniform compression/power...
Old Oct 17, 2006 | 05:33 AM
I stand corrected.
buckz6319
Aug 5, 2017 03:50 AM
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
