pulled the top off and busted the A bolt sensor thing. Options?
Old Apr 6, 2009 | 03:39 PM
Junkers88's Avatar
I pulled the top off the 89 a few minutes ago and while tightening down the A bolt (the one with the anti-rear-window sensor under it) I heard a *snap* and something fell inside the fender. Sure enough after pulling the bolt back out the darn little sensor isn't there anymore and even with the bolt out I can't roll the window back up.
Anyone else have this happen? If so is it common or have I really jacked something up?
Oh and now that I have the top off the neighbor comes over to let me know that we have snow forcast for the weekend.......
Old Apr 6, 2009 | 06:27 PM
Junkers88's Avatar
Anyone? I'll probably have to but the dang thing back on this weekend and I need to be able to roll the rear window up.
Is there a way to eliminate the sensor?
Old Apr 6, 2009 | 06:38 PM
iamsuperbleeder's Avatar
garbage bag and duct tape?
I dunno bro, I'm not a Runner owner, sorry
Old Apr 6, 2009 | 06:39 PM
Junkers88's Avatar
Darn you. I clicked on the thread all happy once I saw that someone replied.
Old Apr 6, 2009 | 06:40 PM
abecedarian's Avatar
real long spring inside to hold the sensor up?
Sorry, can't help. I've yet to take the cap off mine since I've got stuff in there I don't want to lose.
lmao, sry man
HAHA, BET YOU OPENED IT AGAIN!!!
lawl
sorry
Old Apr 6, 2009 | 06:44 PM
Junkers88's Avatar
lmao, sry man
lawl
sorry
Matt16's Avatar
If you pull that panel off the tailgate, you can "hotwire" the motor if you have a car battery sitting around the garage.
Here's my writeup on fixing the relays, in it an over-detailed explanation how to hot wire the motor. Basically, stick the + and - wires from the battery into the blue plug. If nothing happens, switch the + and - and try again. Your window should go back up fine.
https://www.yotatech.com/forums/f116...runner-137193/
Here's another site that may help.:
http://forum.ih8mud.com/79-95-toyota...ay-repair.html
Silas's Avatar
lol worst comes to worse. shove a battery in the back then crawl in from the front of the truck, make sure the back door inside cover is off. unplug the 2 wire connector off of the motor and use 2 wire leads and the battery to roll it up.
I have no idea what sensor your talking about... all my runners/friends the window switches never worked and the wiring was bad so i just starting rigging up some DPDT switches...
EDIT: damn i got beaten to it haha
hehe
Climb inside and find the relay behind the driver's side door. You should be able to jumper it and bypass the safety switch so you can roll the window up.
Old Apr 6, 2009 | 06:54 PM
Junkers88's Avatar
Originally Posted by abecedarian
hehe
Thank you. I'll need to be able to roll it up eventually and this will help.
Old Apr 6, 2009 | 06:59 PM
Duct tape and Hefty bags are another option.
Old Apr 6, 2009 | 07:17 PM
Junkers88's Avatar
After that first post of yours about the long spring you're getting closer than you think to being in the funny book with ol' gangstableeder there.....
Old Apr 6, 2009 | 09:32 PM
If you can't blind them with the truth... baffle them with bulls**t.
Old Apr 6, 2009 | 09:43 PM
DeathCougar's Avatar
Assuming you are talking about the sensor about 1/2 up the quarter panel on the drivers side? just jumper the wires. All the switch does is complete the circuit when the bolt is in, so if you jump the wires together, the system will think the top is on all the time.
bigjstang
Jun 2, 2025 03:56 PM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
Vargntucson
Jul 4, 2015 12:15 PM
