Puling block on 22re pickup
Old 08-04-2009, 04:42 PM
YFZsandrider's Avatar
Is it possible to yank the block on a 22re pickup without pulling the tranny completely out or removing the core supports and grille?
Old 08-04-2009, 04:54 PM
iamsuperbleeder's Avatar
absolutely
Old 08-04-2009, 05:14 PM
olharleyman's Avatar
In case you need a second opinion
Old 08-04-2009, 05:16 PM
Thanks guys!! Did ya just drop it in and back that sucker up on the input shaft?
Old 08-04-2009, 05:21 PM
Pretty much so but there was some wiggling and a few choice words to get it to believe it belonged there.
Old 08-04-2009, 05:26 PM
I know how that goes.... although my words aren't so chosen. They just go flyin' out of my mouth when I'm grunting and sweating with a block in one hand, and a tranny in the other.
Old 08-04-2009, 05:29 PM
yoterr's Avatar
if ya wanna make it a little easier on urself when you put it back in, unbolt the rear driveshaft so you can rotate the input shaft by spinnin the d-shaft makes it a lil easier...
Old 08-04-2009, 05:51 PM
Me too add 92 degrees and 86% humidity sweating like a virgin in a whore house and you just kind of lose your mind and sensibility Hell I think I may have even spoken a language all my own.
Old 08-04-2009, 06:45 PM
once you figure out that you're lining up 2 alignment dowels on the back of the block, one on the top center, and one on the driver's side, then it just takes a little wiggling
for whatever reason, I spend the first 30 minutes wiggling it thinking that the driver's side dowel was the only one and then I kicked myself in the teeth once I felt around and was like DUH, THERE'S ANOTHER ONE
bigjstang
08-25-2021 12:41 AM
crashburnoveride
08-28-2015 09:20 PM
Gamble_STi
07-07-2015 07:54 PM
Nickdigg
07-07-2015 06:04 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: Puling block on 22re pickup
