Power loss when a/c on? help
Old Aug 7, 2011 | 11:35 AM
HAWAIIANSTYLE's Avatar
is it normal for the 3.0 4runner to have a loss of power when the a/c is on? my runner runs fine when the a/c is off but the moment i turn it on it feel like my car is hesitating/struggling to pick up speed.
Old Aug 7, 2011 | 12:08 PM
john4wd's Avatar
When AC compressor clutch is on it's a drag on the engine, turning off AC make the clutch run free tiny bit to no drag so engine feel more power.
Old Aug 7, 2011 | 07:01 PM
StreetPerformer's Avatar
its common to lose power when your AC is on, thats why fuel economy takes a hit when its on.
that is also why you will notice on EFI rigs the AC is wired into the EFI with a sensor so that once it kicks on the idle will pick up so your rig doesn't die
Old Aug 7, 2011 | 07:51 PM
SoCal4Running's Avatar
Completely normal for almost ALL vehicles.
The ones with little HP to begin with notice the most lag.
Old Aug 7, 2011 | 09:16 PM
CajunKenny's Avatar
An activated A/C can consume upwards of 30hp. Yep...you'll feel that.
Old Aug 7, 2011 | 10:39 PM
x-man's Avatar
You geared up? I feel the power loss only when going up like H3 or red hill, other then that I'm good.
Old Aug 8, 2011 | 12:00 AM
yeehaw1's Avatar
yep, completely normal for all motors and vehicles, that's why i haven't never bothered fixing the ac in my yeehaw yet!
Old Aug 8, 2011 | 06:19 AM
blakefogt's Avatar
very normal, sometimes i turn it off to pass people :p
Old Aug 8, 2011 | 06:23 AM
Fink's Avatar
Definitely normal.
Wasn't there a Mythbusters episode about whether it was more fuel efficient to run with your windows down or with the A/C on?
IIRC, they said at city speeds it was more efficient to have your windows down, but on the highway, it was more efficient to have the A/C on...I could be wrong though.
Fink
Old Aug 8, 2011 | 06:42 AM
irab88's Avatar
fink- iirc, you're correct. i saw an article on the same topic with the same results
Old Aug 8, 2011 | 08:52 AM
tj884Rdlx's Avatar
i've got a supplemental question on this topic:
i'm familiar with the additional load a compressor can add, which seems to "slow down" an engine.
but are there some additional vacuum (VAV) system parts, that if leaky could be contributing to his loss of power?
just wondering if there's anything else he should consider and check before dismissing his power loss as all due to the load of the compressor.
Old Aug 8, 2011 | 09:07 AM
irab88's Avatar
good point. might try the idle-up vac lines
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
gmonnie123
Jul 26, 2015 02:44 PM
jackiebrownia
Jul 20, 2015 09:02 AM
