Had to post a couple pics of the last year's progress.
Day 1 Ball joints 🖕 Valve covers Timing belt etc. First trail! Peters Mill run, VA Assateague Isl., MD Fuel pump Softtopper! Most recent pic, needs a bath
Thus far major items I've replaced include (in no particular order):
upper & lower ball joints
Pitman and idler arm
All 4 shocks
Rear leafs, shackles, bushings
Fuel pump, hanger bracket, filter, and line from tank to engine
Front brakes and wheel bearings
Pass. Front brake caliper (seized)
Brake line from pass. Front to lspv
Brake line from rear diff junction to driver's rear drum
Brake master cylinder & booster
Valve cover gaskets
Timing belt, water pump etc
all 3 accessory belts
Fan clutch
Radiator
Ac tensioner pulley (missing when bought)
O2 sensor
Ignition coil
5 tires (had original spare )
inner tie rods
Rear trunk interior trim covers (missing when bought)
transfer case output shaft seal
Rear floor heater heater hoses
replaced all vacuum lines
Throttle position sensor
Coolant temp sensor
Tune up kit (plugs, wires, cap, etc)
pair of wolf steel rear wheelhouse replacement panels (not installed)
been a busy year and haven't even gotten to the bodywork yet lol
previous owner didn't do ˟˟˟˟ on this thing, but that's what I get for impulse buying a suspiciously cheap 4runner on ebay sight unseen lol. Canceled my Bronco reservation for this instead and have been loving it! Wouldn't trade it for anything.
My New 1992 V6 5spd as of August 2021. Before and After. 3rd Owner, very little rust but lots of cleaning to do! 3" 4crawler body lift, Marlin tube bumper, oem wheels on 33"x9.5 Superswampers. 4.88 re-gear with rear spartan locker, manual locking hub conversion.
My original owner 1992 4cyl/5spd 70k miles serviced only by me or Toyota with original paint, no rust, never wrecked baby got T-Boned at the RF wheel. Bummer.
Bought this from an old friend for a winter project. Po said he was tired of putting money into it and hadn't run in 2 years. Trailered it home and had it running in a couple hours. Didn't run good but it had a pulse, and quickly turned into my daily driver.
