Post Your Pics!!!
Old Nov 12, 2020 | 07:04 PM
  #16981
RAD4Runner's Avatar
Just occured to me that free Campsites often have better views than developed ones.
ZION VIEW BLM
LONG CANYON BLM, Canyonlands, UT
BLM BETWEEN MENDON, UT AND MENDON PEAK
Old Nov 16, 2020 | 03:31 AM
  #16982
rattlewagon's Avatar
Awesome shots!
Old Nov 17, 2020 | 06:32 AM
  #16983
YotaRick27's Avatar
Last time with some sun before I tear it back apart for some finish welding and gears
Also a little flex test
Old Nov 20, 2020 | 04:56 AM
  #16984
954runner-3vze's Avatar
My 1995 4runner sr5, 3.0 v6, 2wd
Old Nov 20, 2020 | 09:05 AM
  #16985
trevdog's Avatar
1-ton Toyota
I find that offroad performance is greatly enhanced by adding some ( 1800lbs) weight to the rear-end.
Old Nov 20, 2020 | 03:45 PM
  #16986
nickv351's Avatar
1995 Pickup DLX 4x4 V6
She’s come a long, long way in a year. I bought it last October with 182k on odometer. First thing I did was valve cover gaskets and coolant flush. She returned the favor by blowing a head gasket 3 months later. Since then: Dropped in a 0 mile, rebuilt 3VzE with brand new heads, ARP studs, and mls head gaskets. Doug Thorley headers, Magnaflow cat, Borla muffler and new chrome exhaust tip. New ignition coil, distro, cap, and NGK wires. 4 hole Bosch injectors, LCE pair and EGR delete kit, new AC compressor and lines. Replaced leaky windshield, patched the rusty hole in the floor pan, installed heat/sound barrier and new carpeting. Found and installed used but near mint 60/40 bench seats from eBay. New pitman arm, repacked front bearings, new Moog upper and lower ball joints, new sway bar links. Gave it a 3” lift with rear blocks, extended Bilstein shocks and bj spacers. New 32x11.50 r15 mud terrains mounted on 1 1/4” Trailgear wheel spacers. Replaced all dash lamps with LEDs, and treated undercarriage with Chassis Saver. Most recently just installed new Dorman gas tank, fuel pump, fuel line, and sending unit.
Custom cold air intake box that I fabricated from scratch.
From years of a leaky windshield. Replaced windshield and got rid of that crappy chrome trim.
Cleaned up hole
Welded in sheet metal patch
Floated it with JB Weld
Wire wheeled floor pan and painted with rust reformer
Heat and sound barrier
New carpeting
Old Nov 23, 2020 | 08:37 AM
  #16987
84 yota dude's Avatar
Nice work! No way that truck started life in NJ. Too clean underneath!
Old Nov 26, 2020 | 12:24 PM
  #16988
ztbailey1's Avatar
Happy Thanksgiving!
Hey Yotatech, it's been a couple years since I've been active here, but I've always loved this thread so here's a few updated shots of my '92. But first, @nickv351, Nice work! That's one clean looking pickup!
Last winter up in Georgetown:
Trailered up to move to SoCal for a new job and to start my career:
How she currently sits. Hoping to have the front bumper done by the end of the year!
Old Nov 26, 2020 | 06:12 PM
  #16989
dzldust's Avatar
My 87 runner that I’m getting back in shape,doesn’t need much
Old Nov 28, 2020 | 05:52 AM
  #16990
Steky's Avatar
92 Working
Putting in a little work today. Great little truck I got from an old friend. Hadn't run in almost two years. New clutch, wp and runs like new. Needs some body work under the cab windows, paint and a rear bumper. The Tundra does go much now...lol
Old Dec 12, 2020 | 04:09 PM
  #16991
myprecious's Avatar
my 1993 4runner sr5 mild lift
2.5 street rays bj spacers 2"lifted ome heavy load springs,skyjacker 7000 0-2"lift,toyo open country 33/10.5/15 m,t
Old Dec 12, 2020 | 04:47 PM
  #16992
swampedout's Avatar
5 Year Member
pic didnt show up?
How do you like the ome springs?
Old Dec 17, 2020 | 02:18 PM
  #16993
wallytoo's Avatar
a little snow on the 4runner today.
how it was at 7:30 am. i cleaned it all off, and drove my wife to work.
how it was at 11:00. another 15" on top. ended up with 20" on it to go with the 15 from earlier.
ended up with 35" of fresh snow.
Old Dec 19, 2020 | 04:44 AM
  #16994
90SR5Truck's Avatar
Old Dec 22, 2020 | 01:40 PM
  #16995
Jhoward's Avatar
My first Toyota
Picked up this 95 3.0L (181K) a couple months ago. Truck had not been started or moved in over 5 years. All fluids flushed, all filters replaced, one replaced injector, new tune up parts, a new ignition cylinder and many, many hours working on the paint later......this is what I’ve got. Still working on a high idle and frozen tailgate key cylinder, along with a few other minor issues, but overall she’s come back to life very nicely.
Old Dec 28, 2020 | 05:59 AM
  #16996
cmarv's Avatar
1986 rte
1986 RTE.
looking for a new rad if anyone has any suggestions.
Old Dec 28, 2020 | 11:49 AM
  #16997
Jhoward's Avatar
Aussie Billabong is now on my bucket list. This post is better than any advertising brochure....thanks.
Old Jan 1, 2021 | 07:11 AM
  #16998
87-4runner's Avatar
1987 Turbo 4 runner
CT26 #10 Boost
1982 Supra AFM
LCE exhaust manifold
LCE head gasket APR studs
LCE timing chain kit
Denso OEM TPS
Old Jan 1, 2021 | 07:21 AM
  #16999
87-4runner's Avatar
1987 Turbo 4 runner
175k STOCK
Old Jan 1, 2021 | 07:49 AM
  #17000
swampedout's Avatar
5 Year Member
Very clean!
ive never seen the supra afm set up on that side of the engine bay. Is that a turbo thing?
