Post Your Pics!!!
Old Jul 31, 2013 | 10:13 AM
  #13761
bruno4turbo's Avatar
yea they're sick, my boyfriend has a gasser rc truck that matches his chevy, I want a yota one paint it yellow to match mine
Old Jul 31, 2013 | 02:49 PM
  #13762
kawasakilewis's Avatar
my mini me i made
Old Jul 31, 2013 | 05:03 PM
  #13763
arlindsay1992's Avatar
The 87 got a few little updates. Keep an eye out on youtube.com/TheAlexManVideos for videos showing the OME spring install, BudBuilt install, and how to cure driveline vibrations.
OME springs and TG U-bolt flip kit. No driveline vibrations as some have reported.
This is right after installation. It has settled down about an inch in the rear which makes it just about perfectly level with the 1.5" BJ spacers and stock adjustment T-bars.
Took out the bolt and welded in a 3/8" dowel rod. No worries of the bolt contacting the tank.
BudBuilt single case crossmember. This is sold for stock drivetrain height but it actually brings the driveline up a little bit. This threw off my driveline angles and caused a bit of vibration at high speed. Your results may differ if you have stock springs. I have OME springs which didn't vibrate before the BudBuilt was installed. 4Crawler shims are in the mail.
4Crawler HiLift mount plus a custom mount which allows the HiLift to be locked and secured.
Also added a power inverter to charge phones, laptops, or cameras while I'm driving/wheeling. A 70 amp circuit breaker under the hood stops overdraw and is usually left off to prevent people from stealing my power.
Old Jul 31, 2013 | 05:21 PM
  #13764
93Xtra-Cab's Avatar
^That soft top looks freaking sweet!
Old Jul 31, 2013 | 06:07 PM
  #13765
ToyoTech559's Avatar
runner looks great. any info and pictures of how the extinguisher mount?
Old Jul 31, 2013 | 06:08 PM
  #13766
Ocell's Avatar
Originally Posted by arlindsay1992
That's a clever way to keep quick access to your recovery strap!
It's also great to see that Budbuilt cross member installed. I've got one on order, and I've had trouble finding a good install photo of the single case version. Looking great!
Old Jul 31, 2013 | 06:30 PM
  #13767
Thanks. I'm happy that the P/O bought it instead of me. CanBacks are the most expensive softtops made.
It's a plastic mount that came with the extinguisher which has been hose-clamped to the roll bar. It was done by the P/O and not really my idea of a clean installation. But it hasn't moved in two years so I'll leave it. I also mounted an extinguisher in front of the passenger seat. It's easily accessible, hidden, well secured, and doesn't interfere with the seat sliding. I made a nice mount for it so it looks a bit cleaner than a couple hose clamps.
I have two straps. That's my big one which rarely gets used. My little one rolls up smaller and fits in the little cargo compartment.
The BudBuilt went in pretty easy. It's a nicely built product but keep in mind it will bring your trans up about an inch. In my case it messed with my driveshaft angle. Your results may vary.
Old Jul 31, 2013 | 07:42 PM
  #13768
Ocell's Avatar
I appreciate the heads up. I've got a front diff drop, so I'll keep an eye on my front driveshaft and make sure everything's good.
Old Aug 1, 2013 | 03:35 PM
  #13769
3.0 yoda's Avatar
3.0...... SUWEEEEEET! Freaking gorgeous! Nice work man
Thanks.
Old Aug 1, 2013 | 03:37 PM
  #13770
3.0 yoda's Avatar
Originally Posted by wii_tarded
Hey, what did you do with your old IFS lift stuff? Might be interested in that bracket lift...
i don't have it anymore, give it to a buddy that helped me with my swap..
Old Aug 1, 2013 | 05:05 PM
  #13771
Yamiryder's Avatar
Originally Posted by kawasakilewis
my mini me i made
Sick...
Old Aug 4, 2013 | 11:48 AM
  #13772
FuelforWar's Avatar
Got her all cleaned up today
Old Aug 4, 2013 | 11:54 AM
  #13773
ChefYota4x4's Avatar
Mmmmmmm, NICE, FFWar! More pics, more light, more angles..... please? Lol
Old Aug 4, 2013 | 12:09 PM
  #13774
FuelforWar's Avatar
just a moment
Old Aug 4, 2013 | 12:16 PM
  #13775
Hahaha. ... no rush, FFWar! Just when you get a chance. Thanks
Old Aug 4, 2013 | 12:34 PM
  #13776
FuelforWar's Avatar
heres a few
My turd of a motor 295K
Old Aug 4, 2013 | 09:13 PM
  #13777
RAD4Runner's Avatar
A Day At La Jolla Shores
Ruby Tuesday early to the beach...
... and after a hours of kayaking... passing by this Tacoma (probably 2WD) that's almost down to its rear bumper in sand.
What's a 2WD truck doing on the beach, and worse yet facing the water? A macho truck doesn't necessarily mean it can handle all conditions.
Old Aug 4, 2013 | 10:02 PM
  #13778
2toys's Avatar
Haha he was probally thinking my truck has a lift it can go anywhere. bet he was wishing he spent a few more thousand on a 4x model.
Old Aug 5, 2013 | 12:06 AM
  #13779
Finished, FINALLY, regarding the triple sticks install and readjusting and locating the floor placement for the boot and then with some pretty serious cutting and grinding on the bottom I got the shifter bezel with pocket back in! Woohoo... Lol...
I also secured the console fire making sure the mounting tabs we're fully secured. The pinch welds on the rear most mounting bracket for the console had completely sheered free and the only thing holding it there was a carpet, haha. .....
Are then decided in spite of coming down with something that I need to really push the springs a little bit here and there, to start to break them in so to speak... This thing rides in freaking credible! Lol... Nothing too crazy but it was fun to have every car and truck passing by totally tripping out and wondering what the hell I was doing! Hahahahaha...
I also re did my low pressure line on my new gearbox to cooler location..... So hopefully no more leaky!
Old Aug 5, 2013 | 04:01 AM
  #13780
wii_tarded's Avatar
WORK, Truck....
Put her through the paces Sat. morning. 11 80# bags of sakcrete, and 15 8x8x16 concrete block loaded and hauled home.
Normal stance:
Loaded:
The load:
After unloaded, the springs went right back to the original height. I was hoping the weight would help settle them a little more.
