possible starter problem?
Old Jun 16, 2006 | 04:18 AM
Buck01's Avatar
I noticed my truck turning over a little slowly the last week when trying to start. Then 2 days ago it wouldnt turn over at all. I thought battery was possibly run down. I charged the battery and cleaned cables. Then the truck started great. That lasted one day.
This morning coming to work. The truck started at home(turned over slowly).
I stopped to get gas. Then the truck would not start. Wouldnt turn over at all.
I tried to jump start it nothing still. I have lights and radio so I think the battery is ok. I finally got a couple of guys to give me a push and made it to work.
Do you think this could be a starter problem??
its a 94 truck with 22RE and 5 speed.
Old Jun 16, 2006 | 04:27 AM
Amir904's Avatar
do u get one click and thats it? or a bunch of clicks and see some of the dash lights going on and off? if its one click, its def ur starter contacts, cost u $15 if u rebuild it urself, a piece of cake, even i could do it. if the latter, its most likely ur battery.
Old Jun 16, 2006 | 04:33 AM
Buck01's Avatar
one click..............................
Old Jun 16, 2006 | 05:51 AM
Buck01's Avatar
I am looking at the write up on 4crawlers site..
http://www.4crawler.com/4x4/CheapTri...OnlineOrdering
I called Toyota they dont have the part in stock. Would have to order it.
Old Jun 20, 2006 | 03:28 AM
Buck01's Avatar
I replaced the contacts in the starter. The truck would still not turn over.
I checked the voltage at the battery 12.5 volts.
I was checking the fuses under the hood.(SHould have left them alone)
I tried to pull out the big square fuse that is labeled 80 ALT.
I ended up cracking it. I am not sure what this does????
I went and got a new starter. I hooked it up and the truck turns over now but it will not start. I have spark and I smell fuel and can hear the pump running.
is it the cracked fuse or something else???
Thanks
Old Jun 20, 2006 | 03:38 AM
TNRabbit's Avatar
I would venture a guess that the 80 amp was your alternator fuse and if it is broken, that would explain why it won't start...
Old Jun 20, 2006 | 03:47 AM
Buck01's Avatar
is this a dealer only item? and how much (dollar wise) am I gonna hate myself for trying to pull that fuse out?
That brings up the next question ..how do you pull that fuse out?
I tried pulling by hand. The I tried to pull with pliers ...thats when I broke it.
Old Jun 20, 2006 | 05:52 AM
Buck01's Avatar
I just called the dealer. That fuse has 2 small screws on the bottom that hold it in place. Explains why I couldn't just pull it out. The cost is 10 bucks. I guess I have made more costly mistakes before...still stings a little though.
Old Jun 20, 2006 | 08:48 AM
TNRabbit's Avatar
Lucky You! I've learned the hard way (often) that if you have to force something, you need to stop what you're doing and find more information!
Old Jun 20, 2006 | 09:00 AM
Buck01's Avatar
I will find out how lucky I am when I get home tonight. If this fuses fixes the problem I will be happy. If it doesn't I will take a hammer to the truck : P
Old Jun 20, 2006 | 11:54 AM
celica's Avatar
Maybe try a screwdriver this time - JK
Have you had the battery load tested - just because it says 12.5 with a voltmeater - that isn't what it will be under load & doesn't show the amerage draw available. A lot of shops will test it for free. If you able to get a push start & drive then your alternator is probably OK.
Old Jun 21, 2006 | 03:39 AM
Buck01's Avatar
I haven't had the battery tested..YET..
I replaced the fuse last night and the truck started!!!!!!!!!!!!
Old Jun 21, 2006 | 03:48 AM
TNRabbit's Avatar
WOOHOO!~ SEE, you ARE lucky!
Old Jun 21, 2006 | 03:51 AM
Buck01's Avatar
yep..if it weren't for bad luck..I would have no luck at all.... : )
If I were lucky the contacts would have fixed it and I wouldnt have had to take the starter off 4 times.
All in all though I am happy it is done... : )
Old Jun 22, 2006 | 05:33 AM
kt19's Avatar
Did you buy a new whole new starter? Does the starter have the selinoid on it or is the selinoid seperate from the starter. My truck did this today and seems like a problem that I have had before with selinoids on Fords. How much was the starter?
Thanks
Old Jun 22, 2006 | 05:35 AM
Buck01's Avatar
Yes I bought a whole starter. I came with solenoid and all. It cost 95 dollars.
Old Jun 22, 2006 | 08:30 AM
kt19's Avatar
Thank You
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
clok
Aug 1, 2015 09:42 PM
Hiluxtrucha
Jul 22, 2015 10:00 AM
ZONAYODA
Jul 13, 2015 07:17 PM
colinmil
Jul 6, 2015 04:03 PM
