Plugging 22r AAP
Plugging 22r AAP
Awhile ago my AAP leaked and caused me quite a headache. I got it all figured out and plugged my AAP at the vacuum line, and on the nipple itself coming out of the carburetor.
So far its so good and doesn't seem to have vacuum leaks, but raw fuel is dribbling out of the nipple on the carb as I drive....is this normal? Would it be okay to really plug this thing off for good? (line plug + hose clamp) or would it trap fuel in the carb and cause other problems...and is it even normal for fuel to come out once its warmed up? I was under the impression it was only when cold.
Anybody know where I could buy just the diaphragm?
You know, I might actually have a spare diaphragm out in my spare parts drawer in my toolbox. I can't guarantee I'll get to it today, but if you give me a day or two I'll mail it to ya. It's not new, but it's not blown either.
In the meantime, no harm in just plugging it. Once the diaphragm ruptures, the small amount of the pressure in the bowl could push some fuel out I guess.
That diaphragm will work with an engine hot or cold because it is dependent upon the Bimetal Vacuum Switch Valve (BVSV) to route vacuum only on a cold engine. If your BVSV is not working correctly, then the AAP could be working all the time, or working incorrectly.
http://www.toyomotorparts.com/Page_P...GB11&VAID=2341
http://www.utoyot8.com/FullImage.asp...308-8708%2922R
Part number 21667 (Sub). Looks like about $39 plus whatever freight to you.
sandyota
Feb 4, 2021 11:16 AM
