Please Help! 3vze Coolant Waterfall. Yes, I've Searched.
Old Apr 24, 2016 | 01:45 PM
mj928's Avatar
1989 4runner, 6 Cylinder, Auto.
I just finished replacing the knock sensor. Once buttoned up, I refilled the coolant and coolant comes rushing down on the DS, mostly pouring down that side of the bellhousing, seemingly coming from the ds firewall.
I searched on here, yielding some ideas. I again pulled off the plenum and replaced both the U and J hose. I also checked the torque on the rear sensor/water bridge thing, and it is all good. I was sure to replace both water passage gaskets at the tensioner and rear sensor stack. Also, there is zero coolant in the valley of the motor.
When i pour coolant into the rad, water comes falling out. What did I miss/do I check? I even have a parts 4runner with the plenum off. I cannot seem to find an area to even check. Please help.
Old Apr 24, 2016 | 05:14 PM
MudHippy's Avatar
Any luck yet? Only so many things it could possibly be. Gotta be a leaky/loose hose or a cracked pipe/fitting somewhere. Or maybe a freeze plug I guess.
Old Apr 24, 2016 | 07:39 PM
mj928's Avatar
Thanks for the diagram Mudhippy. No love. I had to leave it all until next weekend. The plenum is off and I will look at it with fresh eyes then. I think the knock sensor work clouded my focus. More then.
Old Apr 30, 2016 | 04:13 PM
mj928's Avatar
Well, it turns out I dropped a washer, missed it when I dropped in the ds intake gasket, torqued it down..... Waterfall!
I feel so dumb.
Old Apr 30, 2016 | 06:20 PM
MudHippy's Avatar
It happens. Even to the best of us. Don't feel too bad.
Old Apr 30, 2016 | 08:15 PM
mj928's Avatar
Thanks man.
Old May 1, 2016 | 04:32 AM
rattlewagon's Avatar
Glad you figured it out!
Old May 2, 2016 | 06:32 PM
mj928's Avatar
Now, in the course of pulling the idler pulley, I managed to throw off timing Since I have no history as to when it was last changed and the timing cover gasket is hard as a rock, I figure it's time for a front motor service/timing belt/wp service. I am sure I'll be back for help. Thanks Yotatech.
Gratuitous pic of the offending beast...
Old May 2, 2016 | 07:38 PM
MudHippy's Avatar
Oh...you're in for a real treat. That's supposed to be sarcastic. But not so much though because I'm about to reveal the secret. Which is the best piece of advice nobody ever gave me. And it goes a little something like this...
Follow the instructions to a T. Don't try and outsmart the manual. Do exactly what it says no matter how dumb it sounds. In particular, the part about the camshaft pulley match pins. Yes, you do want(more like need if you know what's good for you) to remove the pulleys and the match pins. I know. Sounds like a lot more work than is necessary. Trust me, doing so makes the job 10x easier in the long run. Why? Because the key to the whole process is installing the camshaft pulleys without the match pins, and only finger tightening the bolts. And by finger tight I actually mean finger tight, then backed off a tiny bit. The camshaft pulleys need to be able to spin freely during the belt alignment/installation process. Then when the belt is there on where it should be, and you've done the double crank spin verification, that's when you remove the bolts and make the pulleys line up to install the match pins.
Can it be done without removing the camshaft pulleys? Yes. I did it that way at least half a dozen times before I finally figured out IT WAS THE WRONG WAY. I had done nothing but made the whole job ridiculously more difficult than it needed to be. I thought I was smarter than the book you see. NOT!
BTW, 3 words. Drop dead sexy. And I'm not even a 4Runner guy. Hard not to be when I see one looking that good though.
Old May 2, 2016 | 07:53 PM
mj928's Avatar
Follow the instructions to a T. Don't try and outsmart the manual. Do exactly what it says no matter how dumb it sounds. In particular, the part about the camshaft pulley match pins. Yes, you do want(more like need if you know what's good for you) to remove the pulleys and the match pins. I know. Sounds like a lot more work than is necessary. Trust me, doing so makes the job 10x easier in the long run. Why? Because the key to the whole process is installing the camshaft pulleys without the match pins, and only finger tightening the bolts. And by finger tight I actually mean finger tight, then backed off a tiny bit. The camshaft pulleys need to be able to spin freely during the belt alignment/installation process. Then went the belt is there on where it should be, and you've done the double crank spin verification, that's when you remove the bolts and make the pulleys line up to install the match pins.
Thanks for the tips and compliment, Mudhippy.
Hah, I have already been researching "shortcuts". I will make all attempts to avoid the temptation to cheat.
Will my 93 manual adequately cover this for my early 3VZE?
Thanks Mudhippy.
Old May 2, 2016 | 08:26 PM
MudHippy's Avatar
Nope. The 93 FSM don't have enough of the crucial steps. This is one of the rare cases where you'll actually want to invest in the $20 Chilton. Because the online 88 V6 FSM is nowhere to be found. Actually you don't even have to buy it. I uploaded pics of the pages with the install instructions. But they're buried deep in the YT archives by now. It might take me days to find them again. I'll see if I can though.
Old May 2, 2016 | 08:35 PM
mj928's Avatar
Thanks. I can swing that.
Old May 2, 2016 | 08:52 PM
MudHippy's Avatar
It's worth having for more than that reason. It's got the 88 only DTCs(Diagnostic Trouble Codes) and some other stuff that only applies to 88. If you've got a library card they might have one you can check out. My local public library has every one but the ones I go there looking for...of course.
Old May 15, 2016 | 07:25 PM
mj928's Avatar
Great advice Mudhippy! Relaxing the cam sprockets made slipping on the belt, drama free. I was only a lost ps pulley woodruff key from
starting her up.
Between the knock sensor, tb/wp, and speedo cable, I am ready to just cruise.
Next up, ac system overhaul and stereo installation.
steele34
Apr 10, 2016 11:42 AM
gixxer
Feb 18, 2016 06:17 PM
128keaton
Feb 12, 2016 05:35 PM
elaketiger
Jan 30, 2016 06:44 AM
Snowking
Jan 29, 2016 02:03 PM
