Pics of newly mounted 33X10.5
Old Oct 9, 2008 | 02:42 PM
strykersd's Avatar
I'm not a fan of everyone who makes a new thread every time they lift their rig or add new tires, but I figured I'd post my findings with my new 33s for anyone looking to run a similar setup.
I just picked up a set of 33 X 10.5s BFG ATS and took them out for they're maiden voyage yesterday. Before I left I pulled the front inner fender liner and pounded the pinchweld flat.
My setup consists of
86 Toyota 4runner
-3" Downey leaf springs (probably only good for 1" of lift)
-Marlin Crawler 6" shackles (good for 1.25" of lift)
-BJ spacers up front with stock T-bar setting
-2" wheel spacers
-Stock 15" alloys (4.75" backspacing I believe)
Now onto the pics. Sorry for the poser pics, I sold my stock 4 cylinder third member with the aussie locker so I can swap in a V6 with stock 4.88s. Now I just need to buy a new lockright. Wheelin an open rig after being locked just isn't the same...
IFS Flex
Now here's the problem, the tires rub the back of the rear fender wells.
Looks like I'm going to have to do some trimming. I guess I could always just add a body lift or get 1" or 1.5" wheel spacers, but I like the current center of gravity of the runner. Hope this helps somebody.
Old Oct 9, 2008 | 02:58 PM
91slowrunner's Avatar
Looks great man, I like the pillar mount Hellas!
Old Oct 9, 2008 | 03:07 PM
Justinvd's Avatar
That looks wicked, looks indentical to my DD sept i have a black removable top and 35's. VERY NICE!!!
Old Oct 9, 2008 | 04:13 PM
Matt16's Avatar
Niiiiiiiiiice. Wish I had those.
Old Oct 9, 2008 | 04:17 PM
toyNG's Avatar
looking awesome! So do you have the 4.88s in there right now? Or are you still running the 4.10s? If you're running the 4.10s, how do they feel? A buddy was trying to convince me that 4.10s and 33s would be very tolerable. But I don't really believe that, seeing as how my truck is really struggling with just 31s.
Old Oct 9, 2008 | 04:29 PM
SwampThing's Avatar
You put on wheelspacers and you're gonna rub the outside lip of that rear fender. Either trim it a bit, new flared fiberglass bedsides, or get a mild bodylift. Are you sprung under or over?
Old Oct 9, 2008 | 04:30 PM
SwampThing's Avatar
Oh, and can I get a picture of how you mounted those hellas? I've been thinking about doing something like that myself.
Old Oct 9, 2008 | 07:17 PM
Pistonman's Avatar
Maybe you could use a bump stop to slightly limit up travel.
I would also like to see more of the lights. Nice truck BTW.
Old Oct 9, 2008 | 11:37 PM
Matt16's Avatar
That would defeat the purpose of buying bigger tires in the first place- off road enhancement. I think trimming and pounding pinch welds, or maybe a body lift only if the former doesn't work.
Old Oct 10, 2008 | 01:20 AM
ovrrdrive's Avatar
You buy bigger tires for ground clearance, not flex...
Old Oct 11, 2008 | 02:52 AM
91 4Runner's Avatar
Spring over
Old Dec 8, 2008 | 10:47 PM
strykersd's Avatar
Thanks 91_4runner for answering, I was out of town that weekend and forgot all about this thread. Yeah my 4runner is spring over.
About the pillar mounted Hellas, at first I simply just pulled off the 'upper hood' drilled two 3/8" holes and bolted the Hellas in place. They shook way too much, so tonight I pulled them out and put another piece of thin sheet metal under the upper hood and put everything back. The sheet I used was actually just an old exhaust manifold cover that I pounded flat with a 3lb sledge. Here's a pic of the setup. It's pretty blurry, but you can see the small pieces of sheet metal I sandwiched behind the upper hood
It's now more stable. Although it's back on the 4runner, it's not complete. The upper hood is held in place by 2 plastic clips and 3 screws. The screws are towards the center where as the clips are the furtherest to the outsides, so those should help stabilize the lights too. I'll pick two new clips up from the dealership tomorrow and test it out.
Old Dec 9, 2008 | 07:21 AM
ZUK's Avatar
ZUK
On my old 87 Runner I had those same tires and loved em....that and 571 gears with my auto
Mine were perfectly centered in the wheel wheel and didn't rub like yours. I had the factory stock packs with a zuk center coil http://gearinstalls.com/dadcoil.htm to get the 3 or 4 inches of lift....while still having the stock packs and stock shackles. I see you have the Downeys....too bad they didn't do the math when they were drilling the center pin.
4.34runner88
Aug 11, 2018 10:44 AM
Jcrawl94
10
Oct 24, 2015 04:34 PM
Scotto6591
Sep 1, 2015 03:24 PM
tomczaksdiesel
Jul 26, 2015 10:35 PM
jon.r
Jul 11, 2015 03:34 PM
