overheating when the heater is on
Old Dec 6, 2010 | 05:29 PM
A1dreese's Avatar
@ andykrow is the prob only there when you put the heater on or, all the time? my temp is normal only doing the overshoot when i turn the heater on. I've figured out how to manage it but, it's sounding like the dual stage isn't going to be the solution for me either. I kind of like the fact that I can speed up the engine heating and stop it in it's tracks by sliding back to cold for a min or two then put it back on heat no problems. put a new rad and hoses on at the beginning of summer so I don't think thats the prob.
Old Dec 7, 2010 | 07:17 AM
andykrow's Avatar
My problem seems to be there mainly on startup. It's independent of the heater controls. As I understand it the overshoot issue could happen at startup or when the heater is turned on. Why would you think the dual stage won't help?
Old Dec 7, 2010 | 07:43 AM
4Crawler's Avatar
The overshoot problem can happen with heater on or off, really doesn't matter which way it happens. In my case it was w/ heater on and just after startup. Once the engine warmed up fully, it was fine w/ heater on or off.
Old Dec 7, 2010 | 12:02 PM
A1dreese's Avatar
Well, I'm going to put in the dual stage then and see what happens. I can live with it either way..
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
alexcarey
Oct 14, 2015 06:05 PM
woodyth
Sep 30, 2015 06:32 PM
LotOMiles
Sep 14, 2015 11:45 PM
