overheating!
Old Dec 9, 2014 | 07:51 PM
rod1210's Avatar
overheating!
ok do I'm really stuck on trying to solve this problem so I'm asking for some help . my 86 toyota pickup 22rte is overheating. I'm located in the Chicago suburbs so it kinda cold over her right now. the truck blow hot air but as i was driving home the truck started to over heat. when i got home i took the radiator cap off and the radiator was pressurized but when the coolant came out it was cold. so I'm lot any ideas of what it could be?
Old Dec 9, 2014 | 08:55 PM
mbomberz1's Avatar
Thermostat might not be opening
Old Dec 9, 2014 | 11:12 PM
92 Yoda's Avatar
I changed my thermostat this last week with the same symptoms and it solved it. I'd say start with checking thermo, then plugged rad and then water pump.
Old Dec 11, 2014 | 12:11 PM
MAINETOY's Avatar
overheating
Sorry to hear your troubles,check the t-stat but i would guess maybe a headgasket or head is cracked between valves and pressurizing the cooling system.Any evidence of antifreeze in the oil?
Old Dec 11, 2014 | 12:19 PM
muddpigg's Avatar
If you've done t-stat.
X2 check oil for coolant and coolant for oil.
Crud builds up in heater coil, get flushed out then gets stuck in headgasket. Then blows it.
You can pressure test coolant system.
It may or may not blow white smoke if headgasket.
Old Dec 11, 2014 | 04:48 PM
Just_ Rollin''s Avatar
If the coolant wasn't hot then I bet it isn't circulating. Probably some blockage that needs to be flushed.
Old Dec 11, 2014 | 06:35 PM
92 Yoda's Avatar
If your trucks still got the original rad you might as well replace it anyway. I got a nice all aluminium one from lowrangeoffroad for $130.
Old Dec 18, 2014 | 06:30 PM
77lubr's Avatar
How long have you owned the truck? I've seen people who buy vehicles only to find out the previous owner used Barrs Leak or some other sort of HG sealer which also clogs the hell out of your cooling system.
ladybugRC
458
Aug 21, 2020 10:41 AM
Corvoid
Dec 11, 2015 11:21 AM
alexcarey
Oct 14, 2015 06:05 PM
larrys93pickup
Sep 17, 2015 07:05 PM
LotOMiles
Sep 14, 2015 11:45 PM
