no speedo/odometer 92 toyota
Old Oct 10, 2010 | 03:55 AM
jjjlsk8ter's Avatar
i got a 92 toyota pickup 22re i cant get the speedometer to work. i tested the wires going to the speed sensor at transmission, im not getting a ground to the sensor. The hot lead works when i ground to the frame, so i know its good.ive tried searching for a cut wire/etc and found nothing, even tested for ground at the ECU and there is nothing. is there a better/other way to track it down ? does the ground start at the ECU or at the gauge cluster ? any help much appreciated. thanks
Old Oct 10, 2010 | 08:17 PM
scope103's Avatar
I assume you have NO speedometer cable, and therefore have the electronic speedometer (I haven't figured out which years and models have which). I assume that you have an automatic transmission. That means you should have two speed sensors, VSS1 and VSS2. (This https://www.yotatech.com/forums/f116.../#post51500003 picture might help.)
The speedometer is driven from VSS1, which is a 3 wire device. (+12v, gnd, and signal). While thook disagrees, I can't see anyway to test a 3 wire device with just a multimeter. In theory, if you can figure out the connections you could apply +12v and gnd, and then measure the signal lead as you turn the gear.
Does any of this sound familiar?
Old Oct 11, 2010 | 04:46 AM
jjjlsk8ter's Avatar
its a 5 speed manual and yes its electronic , i get voltage if i connect the black/orange wire and the middle blue/green wire i get voltage, but i get nothing from the green/red wire. i i spin the gear with a drill should i be getting any voltage out of the green/red wire ?
Old Oct 11, 2010 | 08:03 AM
scope103's Avatar
On my '94 auto, 12v is on blk/grn (aft), gnd on grn (center), and signal is on grn/red (fwd).
If you can figure out a way to apply 12v to blk/grn and gnd to grn (tiny insulated clips?), the grn/red line will switch back and forth between gnd and 12v. (I think it is once / revolution -- so don't use a drill!)
I didn't use this method; I actually used a square wave generator to apply a signal to the truck. The speedometer worked with the generator, so I (correctly) guessed that the sensor was bad.
Do post what you find; this speed sensor is not well documented, and questions about it come up a lot.
Old Apr 26, 2016 | 02:33 AM
jhowland's Avatar
in a 92 Toyota pickup is there a sensor for the odometer and one for the speedometer?
Old Apr 26, 2016 | 06:07 AM
scope103's Avatar
No.
Odometer and Speedometer are driven from the same point on the transfer case; either by a cable to the combination meter or an electronic sensor (I don't which year/model have which, but the sensor seems more popular around 1992 and on.)
There is a speed sensor in the transmission for the transmission, but it has nothing to do with the combination meter.
Old Apr 26, 2016 | 06:22 AM
jhowland's Avatar
The odometer works but not the speedometer it just slowly stopped working, any ideas
Old Feb 15, 2017 | 08:11 PM
*yota2in2trainingRE*'s Avatar
I have the same issue, My speedometer/ Ododmeter and temp gauge all dont work. I have a 1990 yota pickup 5spd manual and it uses a sensor not a cable. I havnt done any proding around yet but this weekend I will.
Old Feb 16, 2017 | 06:09 AM
rustypigeon's Avatar
Is there anything else that does not work on your instrument cluster? Your #1 speed sensor and temp gauge share the same power source but different grounds. I would suspect the power source, but you would also have other items not working on your cluster such as the oil pressure light, brake warning light and tach (if equipped). The power comes from the "gauge" fuse and is supplied to the combination meter and #1 VSS through black/orange wires.
Get your test light out and check the following...
-First check the "gauge" fuse, I assume this is ok because you did not mention any other problems with the combination meter.
-Unplug the three wire connector at the #1 VSS. Turn the ignition to the on position and check that you have 12v going to the black/orange wire.
-Unplug the the connector going to the coolant temp sensor on the intake manifold. This is the sensor that has only one wire (yellow/green). Connect the test light so that one end is on the yellow/green wire connector and the other end is connected to ground. When the ignition is on, the test light should illuminate or blink.
If your gauge fuse is ok and your fuel gauge works, but you do not have power to the black/orange wire to the #1VSS or the yellow/green wire to the coolant sensor (and your oil, brake and tach also do not work), I would suspect bad wiring to the cluster. A bad connection at the "I9" splice, that would cause the aforementioned problems.
Old Aug 9, 2017 | 04:52 PM
Davis0311's Avatar
did you ever figure this out? My 92 4runner has the EXACT same problem. Trying to avaoid buying another cluster
Old Aug 9, 2017 | 04:53 PM
Davis0311's Avatar
can you you take a pic of where the "I9" splice is located?
Old Aug 9, 2017 | 05:18 PM
All I did was replace my speedo CABLE yes cable in a 1990 yota pickup and I also replased the temp gauge when I did and enging swap. I found out that if the pin in the back of your odo is slid out a little it will kep numbers from turning so check that if you have an issue with fhat but its most likely a soeed cable. Now I did have one issue and that was finding the little metal piece that alows the speed cable to maye with the tranny
Old Aug 9, 2017 | 05:58 PM
Davis0311's Avatar
Oh I read that you had the sensor model vicethe cable one. Mine is an electronic speedo. Thanks thogh
Old Aug 9, 2017 | 08:13 PM
jhowland's Avatar
I have a 92 Toyota pickup, and all of my gauges quit working. I found out it was a fuse.
Old Aug 10, 2017 | 02:53 AM
Davis0311's Avatar
it's not a fuse I checked. And everything else works except the speedo/odo and temp qauge.
Old Aug 14, 2017 | 02:45 PM
Davis0311's Avatar
so I followed your directions. And got no power to the #1 vss. And no light at the temp sensor wire. What would be next. Where does the power come from?
Old Nov 29, 2017 | 06:22 AM
Austin Dube's Avatar
HI, im new to the forum,
I have the same problem on the same pickup 92 toyota 22r-3 5 spd. Other gauges and lights do work so is it the ground? or u think its the cable?
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
