No Power Until 15 MPH
Old Apr 14, 2013 | 09:34 AM
cleverlion's Avatar
1995 4Runner 3.0 V-6
325,000 Miles - NO Smoke with Minimal Oil Consumption
Truck starts right-up (but NO Fast Idle Until Warm) rough idle. Idle is set above 1,000 to keep running. I shift (Automatic) manually to get up to speed. Has No power until 15 MPH, then Runs Strong quickly as I then shift to 2nd, then to 3rd (D) & runs great up to freeway speed. No "Check Engine" lights are on. Their is also a quick "Ping" upon take-off (only).
I just bought vehicle like this - thinking it's a simple fix ?
Thanks for your time & help ( :
Michael Patterson
Old Apr 14, 2013 | 09:37 AM
B-Fake's Avatar
Torque converter maybe.
Old Apr 14, 2013 | 10:12 AM
scope103's Avatar
What is the ignition timing set to?
Old Apr 14, 2013 | 10:33 AM
bone collector's Avatar
check condition of tranny fluid. i suspect its low or at least need to be changed. its probably time for a tranny filter/fluid change anyway with that many miles. as for the rough idle, check for vacuum leaks, properly set tps, afm, timing etc etc. good luck and keep us posted
Old Apr 14, 2013 | 10:40 AM
also i would check for stored codes, even if the check engine light is not on
montanatruck
Feb 26, 2017 07:07 AM
Tonetrk
Aug 6, 2015 10:06 AM
Sidherish
Aug 2, 2015 01:42 PM
vanion2
Jul 29, 2015 06:17 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
