No power problem!
Old Aug 22, 2014 | 09:25 AM
TheRoad4Runner's Avatar
No power problem!
Hey guys,
I own a 95 Got a 4R. Runs and drives smooth. It has 245k original on the 3.0v6. While driving at highway speeds, coming up normal highway hill inclines at 70mph, I will lose speed. I can adjust throttle to 75%-100% and will stay at the current speed. But it won't accelerate up these hills. Btw this is in 5th gear just for clarification. The truck has a 3.0 inch body lift and I'm running BFG 33/15/1050 AT KO's on it. Any ideas?
I know for a fact that the timing is correct. So I'm at your mercy. I have not done compression tests, as I'm scared that will be my issue.
Old Aug 22, 2014 | 09:31 AM
JasonYota's Avatar
Tried downshifting? Sounds like there isn't a problem
Old Aug 22, 2014 | 09:40 AM
These are not hills that require a downshift by any means. That's the issue. Please take my question seriously.
Old Aug 22, 2014 | 09:52 AM
millball's Avatar
Moving 2 tons uphill @ 70 mph takes some power, accelerating from 70 mph in 5th gear while travelling uphill takes even more power.
Your 3vz-e only made about 150hp when it was brand new, now its got a quarter million miles on it.
I think you're expecting too much. A stock 4Runner is no muscle car.
Old Aug 22, 2014 | 09:58 AM
I've driven heavier vehicles with less power and still could accelerate uphill. So that's why I asked this question...
Old Aug 22, 2014 | 10:14 AM
RJR's Avatar
RJR
I agree with previous posters. That's pretty normal behavior for a 3.0 in a 4runner, especially with 33 inch tires and the stock 4.56 gears. If you want to be able to accelerate going uphill at 70mph in 5th gear you need a bigger engine or 4.88 or up gears.
Once thing you can do is run mid-grade gasoline. The ECU will advance the timing further because of the lower propensity to knock, and give you a bit more power. The effect is noticeable, and the increase in fuel mileage just about exactly pays for the increased gasoline price. About 5% increase in mileage, power, and cost.
millball's Avatar
What vehicles specificly?? Did they have a quarter million on the clock?
Old Aug 22, 2014 | 10:18 AM
RJR's Avatar
RJR
Oh, and BTW, if you have 33" tires with stock 4.56 gears and haven't changed the speedometer gear, 70mph on the speedo is really 75 on the ground.
Old Aug 25, 2014 | 09:52 AM
Kalihi,HI's Avatar
Aloha from Hawaii, I've been dealing with a similar issue, but with loss of power even at low speeds and small hills. It started after I did my own water pump and timing belt (which I re-did 3 times). I took my truck to a mechanic and it turns out that my timing belt was off by 1 tooth on the camshafts...I was so sure I had done it right and had everything lined up...He also told me after doing a compression leak down test that my cylinder #2 is misfiring...screw me...I had tested compression myself and all 6 cylinders tested good with an average of 145psi, but I was not able to perform the leak down test which the mechanic said shows that #2 cylinder is not holding pressure. What can I do at this point? Is it ok to drive my truck? Any suggestions as to what could cause the misfire? Mahalo!
Old Aug 25, 2014 | 10:15 AM
millball's Avatar
If the misfire is originating in # 2 cylinder, the same cyl that your mechanic says has a compression problem, I think you may likely have found the reason for the misfire.
I'd check the valve clearances, and if loosening up some tight valves does'nt restore the compression, It's probably valve job time, or engine overhaul time.
Old Aug 25, 2014 | 12:17 PM
Badger62811's Avatar
My 94 pickup wouldn't do 70 downhill in a hurricane. That was with a 22re and 31" tires. I'm pretty sure what you're experiencing is completely normal. 5th gear, wow. I never get to use 5th gear. Pretty sure my 89 would do 70 but not in 5th gear or uphill in 3rd.
Old Aug 25, 2014 | 04:35 PM
SacRunner's Avatar
This was completely normal for my 3.0 with 4.56s and 31x10.5s up to about 1500 ft in elevation; above that, I'd have to drop it to 4th to maintain. The sweet spot on the 3.0 is just about 3,400-4,000 rpm, much below that and you'll need to down shift, too much over 4,000 and you're just dumping gas for no good.
Be happy you can do that, with 33x10.5s on mine I would routinely need to drop to 3rd to keep it above 60 on even the slightest inclines; the idea of 70 uphill was just off the table.
I know this isn't the answer you want to hear, but you're about as good as you're going to get with a 3.0, you may see a little (emphasis on LITTLE) benefit from headers and a high flow muffler but that's about it. You'll see your best improvement by re-gearing to 4.88s, but that won't give you any more power, it'll just move the engine's power band back in-line with the transmission gear ratios for optimal drive-ability. Don't waste your time on an intake (unless its $20 for an ISR, which only helps throttle response, but does nothing for overall power), unless you personally own stock in any of those companies or enjoy throwing away money.
Personally, the only cure to the "problem" you have is to swap a different motor; that's ultimately why I, and a lot of others, have a 3.4 swapped in, while others opted for even bigger, more powerful motors. I feel that the 3.4 was the motor that should have been in these trucks, its just too bad that it took Toyota until 95.5/96 to introduce them.
Jun 1, 2021 01:51 PM
Sleaker
Aug 26, 2020 06:03 AM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
