New block or use old one?
Old Oct 28, 2011 | 11:02 PM
taylorham5842's Avatar
So I purchased a 94 pickup (finally) a year ago. Got a good deal had a LC motor.
Well I was slightly taken... I (my girlfriend) blew a head gasket. Pulled head and #1 piston was missing a 3/4 inch piece. I had a mech buddy look at it and he said that happened way before head gasket.
I put new LC pistons/rings in but had to hone #1 cylinder to get rid of gouges.
Now #1 has out of limits piston wobble.
Head was pressure tested good but the guy said the valves were sitting a little weird... IDK. Cylinder head depot South Fl. Good guys.
Truck smokes like a toothless hooker. Spark plugs foul every 100 miles.
So here's my real question...
Should I keep throwing money at this...
Buy a short block and use the head I have?
Or should I get a new block/head. But im gonna have it bored with a cam installed if I go this way.
Old Nov 2, 2011 | 01:35 AM
Rebel Lady's Avatar
you are my same boat. I have not decide to replace new one or rebuild notor on my '87
Old Nov 2, 2011 | 07:59 AM
Yeah it sucks. This is my winter truck and winter is about here. Im thinking im gonna pull the motor since my cylinder block is the culprit and rebuild this winter.
Dont think im gonna go thru LC engineering again tho.
Old Nov 2, 2011 | 09:27 AM
TNRabbit's Avatar
I'd try to find a totaled truck with a donor engine...
Old Nov 2, 2011 | 10:17 AM
iselloil's Avatar
Have mike build you one at sunwest.
http://www.sunwestautomotiveengines.com/lb-toyota.html
Old Nov 16, 2011 | 04:48 PM
All 4 plugs foul... Does anyone think my valve seals are bad? I dont remember if they put new ones in when the re-did the head. Maybe Im getting oil leakage down to my cylinders?
Old Nov 16, 2011 | 06:34 PM
Mandy Tuning's Avatar
you have bad stem seals and possible guides.my truck block have so much clearance after cutting the ridge that a old mercedes diesel engine is quieter than my 22rte and no spark fouls or smoke,only lot of blowby under boost.
Old Nov 17, 2011 | 07:09 AM
skypilot's Avatar
Find a donor truck and take the engine. Stop throwing good money after bad.
Old Nov 17, 2011 | 09:49 AM
Im going to replace valve seals this weekend. If that dosent work...... Then motor is coming out.
Iceman4193
Oct 16, 2015 10:50 AM
alexcarey
Oct 14, 2015 06:05 PM
moparbay
Oct 6, 2015 09:24 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
viesail
Sep 5, 2015 04:23 AM
