New 3.0: Lack of Power
Old Apr 6, 2012 | 08:49 PM
vasinvictor's Avatar
You cannot. It's severely retarding the timing. Only way is to pull to end and replace the wire and/or knock sensor. It's 95% times just the wire that's broken. They get brittle. Just suck it up and fix it the right way. Sorry.
Old Apr 6, 2012 | 08:54 PM
93tonkatoy's Avatar
I didn't figure there was anyway around. The wire is fine however.
Old Apr 6, 2012 | 09:27 PM
Kiroshu's Avatar
Knock sensor is a common "power killer" on the 3VZE. Replace sensor and wiring harness and you'll notice the power gain. The person who re-built and or replaced the engine shoud have known better.
Glowing manifolds are from an excessive rich mixture "dumping fuel" improper air/fuel mixture.
Old Apr 7, 2012 | 01:28 AM
iselloil's Avatar
I was fighting the same issue. New Tps,17,000 miles on the engine,new everything.Ended up being the connector on the TPS and MAF. Both had bad contacts.
Old Apr 7, 2012 | 06:06 AM
  #25
93toyrunner2's Avatar
Originally Posted by 93tonkatoy
What kind of resistor can I put on that knock sensor? I ran my wire the wrong way when I rebuilt it an also now I'm having issues with my exhaust. The manifolds are glowing red and it's getting decent flow out the exhaust. Possible plugged glass pack?i checked the timing on the cams and it's good. The distributor checked our as well done a full tune up and still nothing. I'm so stumped. I gotta get power before I can go play in the trails again.
Bypass it. See the following thread about doing this. You will need another knock sensor and some coax cable to reroute it.
https://www.yotatech.com/forums/f116...99/index2.html post #27
I did this and it has worked for 6 months. Have to re-torque it occasionally.
Old Apr 7, 2012 | 10:09 AM
  #26
93tonkatoy's Avatar
when I rebuilt the engine I didn't run the.knock sensor the right way. So its not even plugged in.
Old Apr 7, 2012 | 10:42 AM
  #27
93toyota4x4's Avatar
When I put my engine back together after changing the head gaskets in my '93 I had manifold glowing and it was because I goofed and had the distributor timing way off. I also had a knock sensor code on that engine for 5 years and it ran fine, no lack of power.
Old Apr 7, 2012 | 10:51 AM
  #28
93tonkatoy's Avatar
You test the check engine light with te1 and e1 correct?
Old Apr 7, 2012 | 08:53 PM
  #29
93tonkatoy's Avatar
I installed one in the engine lift bracket and.still.have the.same problem. Possibly flash it out of the computer??
Old Apr 8, 2012 | 07:46 PM
  #30
Kiroshu's Avatar
^---- Problem maybe..? -_-
Old Apr 9, 2012 | 08:08 AM
  #31
93tonkatoy's Avatar
It ran just fine without it hooked up until the fan blade exploded.
Old Apr 9, 2012 | 08:49 AM
  #32
jaymz3's Avatar
i have dealt with similar "lack of power" and rich smell, i got an O2 code, fuel economy was in the toilet ( <10mpg!) replaced sensor with denso oem replacement and a new AFM (long story on AFM) since those 2 replacements and shaving a little weight off right foot, i am averaging 16-17 mpg, 14mpg in city, best fuel economy since i have owned it, still a little slow on takeoff but seems to have SOME power returns
Old Apr 9, 2012 | 10:19 AM
  #33
TNRabbit's Avatar
Good advice.
Again, the knock sensor WILL reduce ignition timing to ZERO if it's not reading. That makes power go to crap.
Old Apr 9, 2012 | 11:21 AM
  #34
jaymz3's Avatar
is it possible for this to happen without a knock code? like i said i am a little underpowered and smell rich also and looking for answers too
Old Apr 9, 2012 | 03:38 PM
  #35
93tonkatoy's Avatar
I'm at 8mpg hwy and I have maybe 20hp max lmao.
Old Apr 9, 2012 | 05:24 PM
  #36
TNRabbit's Avatar
If the knock sensor is NOT connected, you SHOULD be getting a code. Don't understand that one, unless your CEL bulb is burned out...
Old Apr 10, 2012 | 02:59 AM
  #37
93tonkatoy's Avatar
I am gettin the code 52. Also a code 22 for coolant temp sensor open more than 500 ms??
Old Apr 10, 2012 | 06:00 PM
  #38
93tonkatoy's Avatar
How do you ground the shielded wire straight to the ECM? I was thinking the test terminal e1 but that changed nothing. I rerouted it to the right front engine hook. What am I missing. I did use shielded cable wire for temporary use. Are you supposed to let the shielding touch the copper wire? I have no idea what to do.
Old Apr 10, 2012 | 06:17 PM
  #39
93tonkatoy's Avatar
Nvm I'm gonna try and put it in the other side as soon as my new wire comes In and I'll fill you guys in from there. Possibility that sudden shock could mess up mass air flow sensor?
delmert
Sep 30, 2015 04:34 PM
Poppie51
Aug 15, 2015 11:02 AM
agrout
Aug 13, 2015 06:12 PM
Sidherish
Aug 2, 2015 01:42 PM
