Needs a new head? ( see pic )
Old Jan 5, 2011 | 04:15 PM
rdowney78's Avatar
First post here, this is a great site with tons of valuable info! hats off to all that post here.
I have an 88 runner, water in oil, I yanked the head and found the gasket seperated exactly where I circled on the picture. Also the head looks to be pretty damaged, pitted, corroded right where the gasket sits.
my question is- Is this repairable? the #3 and #2 cylinders are showing the same thing, just not yet as bad.
Or should I search for a new or prefferably used head, as money is tight.
Attached Thumbnails Needs a new head? ( see pic )-22rehead.jpg   Needs a new head? ( see pic )-22rehead2.jpg
Old Jan 5, 2011 | 04:19 PM
xxxtreme22r's Avatar
hard to tell, but I would say that is repairable by having the head face milled at a machine shop.
Old Jan 5, 2011 | 04:21 PM
snobdds's Avatar
From the picture it's hard to tell. I would clean it up real good and post another pic to know for sure.
A good machinest could true it up for you if the head turned out to be ok.
I wouldn't cast it off as a gonner quite yet.
Old Jan 5, 2011 | 04:29 PM
RMA's Avatar
RMA
where in nor cal are you i have a good used one .. pick it up its yours .
Old Jan 5, 2011 | 04:39 PM
rdowney78's Avatar
I am in Sacramento.
I will clean it up and take a better picture. My concern was that the corrosion is pretty deep. And if the cost of repairs outweighs the cost of a used head, than whats the point.
Old Jan 5, 2011 | 04:42 PM
Personally I wouldn't get a used head and just slap it on, I would have it milled anyway.
Old Jan 5, 2011 | 05:21 PM
rdowney78's Avatar
Picture update on top post.
Old Jan 5, 2011 | 05:24 PM
snobdds's Avatar
Well, I think it's time you start looking for a new head.
Old Jan 5, 2011 | 05:25 PM
x2, unless you can find a machine shop that can fill that in, which is probably possible.
$348.00 from engnbldr, complete head drop it on and go. http://www.engnbldr.com/head_shop.htm
Old Jan 5, 2011 | 05:49 PM
RMA's Avatar
RMA
Im sure somebody could fix that head but for how much ?
ideally yes get a new head .. if a shops doing the work for you yes get a new head.
if your doing the work and your really in a bind ..a used head will work for you its been done and will continue to be done some with problems some without .
this engine is really easy to work with so its not that big of a deal i would think if doing the work your self .
i have a good used head ,I wrote 120,000 miles on it when i put it away. .
i did take the valves and such off .. have some brand new valves and springs for it ..if your ok lapping on some valves then come get it its yours .. free man .. im just trying to clear some stuff i have around here. the heads free give me $40 for the valves and springs .. you dont need the valves the heads still free.
or even take the head to a shop have them do it .. .. what ever you do with it i dont care .. im just saying its here if you want it .
Old Jan 5, 2011 | 05:54 PM
snobdds's Avatar
I would hop on that like a...well...
Very generous of you RMA
Old Jan 5, 2011 | 06:14 PM
RMA's Avatar
RMA
its just one of those days i guess not always in this giving mood ..
seriously just tired of seeing so much stuff at my house ..
2 -1uz motors one good one with a burnt valve
1 complete 3.0 good .
1 complete 4.7
1 set of 3.0 heads
1 bare 1uz block
1 bare 3.0 block
? ifs axles
? rear axles
1 set 4:56 diffs
1 set 4:10 diffs
and on and on ..
tired i tell ya ..
Old Jan 5, 2011 | 06:21 PM
rdowney78's Avatar
Well I much appreciate it man, killer deal. Thanks again.
What do you want for the gears?
Old Jan 5, 2011 | 06:24 PM
RMA's Avatar
RMA
hahaha well .. i really want to keep them having 2 4runners who knows when ill need them .. but maybe ill feel different when you pick the head up . Not for sale right now ..
Old Jan 5, 2011 | 07:12 PM
tonetti's Avatar
I am really in need of a good head, if the other guy doesnt want it, let me know if your offer still stands, I'm located near Bear Valley, about an hour out of stockton.
Old Jan 5, 2011 | 07:39 PM
CitrusTheDragon's Avatar
RDowney make you an even better deal, I will use my shop price to have the head milled you pay the price the shop would charge me and I will put the valves in free. PM me for more info
kgcwb44
Jan 29, 2023 10:02 AM
o2raybid
Sep 4, 2015 12:45 PM
Sep 4, 2015 09:27 AM
94 Newbie
Aug 6, 2015 10:33 AM
toofly1999
Jul 25, 2015 07:09 PM
