Need Help , what did i break
Old Mar 6, 2014 | 05:00 PM
combatcarl's Avatar
It can be installed on the truck, but it's easier, in a way, to remove TB then install TPS. Lets you be a little more steady, less reaching in and easier to adjust. Can be a little tough hitting the bottom screw with TB mounted. Unless you have hex/allen screws.
Old Mar 8, 2014 | 01:52 AM
wyoming9's Avatar
Red face
How did you make out I got called to work early then I kinda forgot all about looking to now.
If your good to go great if not send me a PM to remind me.
Old Mar 8, 2014 | 04:16 AM
highway's Avatar
hey thanks, my brother-in-law has one so I should be good to go....thanks again
Old Mar 8, 2014 | 05:29 AM
highway's Avatar
Question, the part number is different on this sensor...... Will it still work?
# 89452-12040
198500 0330
Old Mar 8, 2014 | 06:26 AM
  #25
wyoming9's Avatar
Red face
Maybe !!!
Toyota is great for giving the same part different numbers
If the resistance is the same so your ECU sees the values it needs to see it will work.
I never needed to know if they were all the same from the mid eighties to 95 perhaps someone does know.
Old Mar 8, 2014 | 06:36 AM
  #26
highway's Avatar
Thanks, by checking resistance does mean using feeler gauges and meter like on the crawler link above?
Old Mar 8, 2014 | 06:49 AM
  #27
wyoming9's Avatar
Red face
Yes if it gives you the readings your looking for your good to go!!
Old Mar 8, 2014 | 08:31 AM
  #28
combatcarl's Avatar
Yeah, when I bought one I just checked to make sure it would go open/closed circuit, and that the resistance sweep across its range was constant, and didn't have a dead spot anywhere. Many times, they're misadjusted when you find them still on a throttle body, so the exact resistance ranges don't always happen. An old school analog meter will pick up a break in continuity/dead spot a little more visibly than a digital meter.
Old Mar 13, 2014 | 11:57 AM
  #29
highway's Avatar
well , the tps sensor I got will not fit on my throttle body , the plugin is different and it is clocked different on the backside. wyoming9 do you think you might have one? the part number is :
P125
89452-28030
198500-0201
RDubya
Feb 10, 2017 04:46 PM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
JookUpVandetti
Sep 24, 2015 02:58 PM
