Need help with a cross threaded bolt
Old Jun 5, 2007 | 03:22 PM
Red3.slow's Avatar
So this past weekend I screwed up my tie rod and steering rod. I had already unfortunately had the recall done, anyway I digress. I need some help with a problem I've run in to, The threaded stud that one of the inner tie rod bolts to the steering rod by has a few screwed up threads is there any way I can
a fix the threads
b. replace the stud with out replacing the inner tie rod
Old Jun 5, 2007 | 03:30 PM
91muddog's Avatar
try using a thread chaser on it, usually works for me.
Old Jun 5, 2007 | 03:35 PM
cnctony's Avatar
Not sure what a thread trace is but go buy a thread file or a die AT SEARS AND YOU will be good to go.
Old Jun 5, 2007 | 03:41 PM
isaac338's Avatar
thread chaser. it's like a tap or die but less agressive so less chance of accidentially destroying the threads completely. gray tools makes a nice "thread restore" kit with various inner and outer thread restorers and some thread files. about $400.
you want a thread chaser or restorer so you won't crossthread a die and completely ruin the stud. a chaser won't cut new threads, only restore old ones.
Old Jun 5, 2007 | 03:58 PM
Red3.slow's Avatar
where is the best place to pick one of those up. I've seen thread taps but none of those.
Or can anyone tell me what thread chaser or thread file I need for that inner tie rod bolt
Old Jun 6, 2007 | 05:54 AM
ewong's Avatar
Buy a metric pitch guage to measuer the thread pitch
Get a metric bolt hole guage to tell you the diameter of the threaded bolt
Thread files usually have 4 sides with EIGHT different pitches on them (different on each end).
Tie rod MAY be left hand threaded (I dunno off hand)...
Old Jun 6, 2007 | 07:09 AM
Marc's Avatar
Why not just replace the inner tie rod end?
Old Jun 6, 2007 | 07:21 AM
Red3.slow's Avatar
I'm starting to think about that
Old Jun 6, 2007 | 07:24 AM
Red3.slow's Avatar
just found this advance auto parts, Tread Saver TIE ROD END TRDSV
Old Jun 6, 2007 | 07:51 AM
4Crawler's Avatar
I have a small thread repair file, has a 60 degree angle one one edge with file teeth cut along it. Have used it many times to repair threads. Got it at the local hardware store. With just a single "V", it'll work on any thread, SAE or metric.
Old Jun 6, 2007 | 10:23 PM
curtiswyant's Avatar
I'd try running a tap through it. If that doesn't work, replace the part. It's too much hassle to try to heli-coil etc etc.
80Truck
Oct 12, 2025 07:25 PM
BeMiceElf
Oct 10, 2015 09:40 PM
priest16
15
Aug 6, 2015 07:43 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
1996Taco
Jul 20, 2015 12:02 AM
