Need help with a bolt
Old Nov 5, 2009 | 01:34 PM
A_CavanaughWebb's Avatar
Also. cut it, compression fit it? umm..Not..sure what that means or how to do it, but if it lasts for three years when done right, I'd really like to know what to do.
Old Nov 5, 2009 | 01:43 PM
theAuthority's Avatar
User Requested Ban
Originally Posted by theAuthority
do not use pb blaster or wd-40.
use a mix of transmission fluid and acetone. It works 1000 times better than either of those.
mix it up, rub it on and let it sit overnight.
can reduce the breaking power from 500 ft-lb to 20 ft-lb.
start reading
do not do a compression fitting, just buy a new line if you have to cut it. I would try everything under the sun before I cut that line. Pain in the arse.
Compression fitting >>
Old Nov 5, 2009 | 03:07 PM
If I've crimped the line though, would that mean I'd have to replace it? Or can the fuel still get through? I'm now more worried about that bend I put into the line, then the broken fuel hose piece i need to get out of the other end. I'm going to go ahead and do the ATF-Acetone mixture. probably raise some container up to the piece on a jack, and fill it, let it soak and see what happens. I'll post the results. Anyone know where to get Acetone..I'm not quite sure wtf that is.
Old Nov 5, 2009 | 04:16 PM
peow130's Avatar
Acetone? Check the paint department at like home depot or lowes.
Old Nov 9, 2009 | 06:46 PM
  #25
>.< Acetone and ATF didn't do a thing. I think I'm just going to replace this damn hardline. lol screw it! I wasn't able to get my friend to help me out. I had to go to some wedding. So still it sits....no progress. >.<
Old Nov 9, 2009 | 06:48 PM
  #26
User Requested Ban
haha, that's funny ATF and Acetone didn't work.
so much for that penetration comparison.
I would have replaced the whole line already. New > home made
Old Nov 9, 2009 | 07:06 PM
  #27
well. It did say a "Scientifically rusted environment." ...lol I don't think this kind of "stuck" could be created by any scientist without them taking 5 or 6 years to do it lol. I think I'm just going to replace that hardline. Screw-all lol. I need to get this puppy moving.
some drunk guy
Aug 3, 2021 06:09 PM
Zach_trun
Jan 22, 2020 04:42 PM
mistershmi
Jan 5, 2016 11:07 AM
JUICE222
Oct 13, 2015 08:50 AM
JookUpVandetti
Sep 24, 2015 08:56 AM
