Need electrical advise
Old Jul 26, 2006 | 11:57 AM
jakek's Avatar
Background. Bought 86 4Runner and while driving it around the charge light and brake light would flash on and off with bumps. Allready checked fluid level etc. Using the back window when they would come on would turn the lights off sometimes, but sometimes back window wouldn't work. Sometimes turning car off for a second would also turn them off, and all would be normal again.
Now. Two days ago when I was almost home, only the charge light came on and wouldn't go off with my normal meddlings. The rear window and rear wiper ceased to work as did the temperature, and fuel gauges also. Car still starts strong, and all other components work great.
Any help would be awesome. Thanks.
Old Jul 26, 2006 | 12:05 PM
leebee's Avatar
best bet is to check out www.4crawler.com , more pertinent information than youll know what to do with! a great resource for first gen runners.
welcome to the group, please enjoy your stay and try to be gentle to your wallet.
lee
Old Jul 26, 2006 | 08:26 PM
jakek's Avatar
Thanks
Thanks leebee,
I took care of the gauges and the back window. So now I'm back to square one, where the brake and charge lights just flash with bumps. I'll work on that one tomorrow.
Old Jul 26, 2006 | 08:29 PM
DeathCougar's Avatar
I can almost garuntee its the fuse box under the drivers side of the dash. I have fixed this problem in a few rigs, seems to be a common problem. The female portion where the fuses goes in begins to corrode, and will flicker in and out of working. Try jiggling those fuses (the charging and ignition fuses) and see what happens. Also pull all your fuses and check for corrosion.
Old Jul 26, 2006 | 08:40 PM
jakek's Avatar
Thanks again
Thanks for the tip. I did notice a little corrosion on those ends.
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Sep 28, 2015 11:21 PM
Project90
Sep 24, 2015 11:40 PM
Boomer8404
Sep 24, 2015 01:12 PM
xzen73x
Sep 14, 2015 03:00 AM
