Need advice on possible short.
Old Jul 5, 2014 | 11:16 AM
PETDOC's Avatar
Starter/alternator guy insists he saw an abnormal current that was reduced by pulling fuse #6. I can't find it.
Put everything back together 6 days ago. Thus far no abnormal current measured and battery remains fully charged.
I will just keep driving it and if problem reoccurs try and localize it with multimeter.
Old Jul 5, 2014 | 12:32 PM
mct75's Avatar
This looks like a ferrite choke but it is not. This is the equivalent of the appendix in human terms. I am not aware of any 4Runner owner on T4R.org or Yotatech who had put this to any use in the past 30 years.
What is that thing for?
Old Jul 5, 2014 | 01:43 PM
PETDOC's Avatar
It appears to me it would make it easier to replace (or attach) the alternator harness. Instead of having to pull the wire from the battery you can disconnect the alternator harness at that point. The other connecting points of the alternator harness are all in the same vicinity.
Old Jul 5, 2014 | 09:10 PM
RAD4Runner's Avatar
Like I said above ^^^. Search function of appendix
Then you're not really replacing the harness. The longer part of the alternator wire is from that point to the battery. If you really want to replace the alt wire, no choice but to dig into that loom to the battery.
you are more likely to need to replace the alternator than to need to replace the harness. Either way, you simply disconnect this (instead of trying to pry open that plastic housing):
Again, can anyone in this forum share what he used that for
Old Jul 6, 2014 | 12:20 AM
  #25
wyoming9's Avatar
Red face
I never gave it a thought I thought it was a choke but had no idea why it was needed.
Some sort of shield generator to keep Dragons away??
Attachment point for the Flux Capacitor harness??
I pretty much narrowed it down to these two things
ashamsuddin
17
Jul 22, 2024 03:59 AM
Steven.m.paulk
Jun 7, 2020 10:45 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
charlie_fong
Sep 27, 2015 10:06 PM
taraf
Sep 25, 2015 02:57 PM
