is it my clutch or tranny...crazy vibrations
Old Apr 22, 2010 | 09:38 AM
Myron's Avatar
so a few weeks ago i noticed this crazy vibration when i was on the freeway.
the shifter was vibrating, the floor boards was vibrating and i mean shaking.
so i slowed down and noticed a noise that i didnt hear before..Honestly sounded like a 18 wheeler coming to a stop.
what i noticed was when i lay of the gas at about 45 50 mph there is a crazy vibration, sounds like metal is running next to each other. when i hit the gas, the vibration goes away.
i looked around and i know its not the cv joints because i just did them in jan.
My guess is the tranny, also when i shift from 4th gear to 5th gear..doesn't feel like it shifted..
i down shift from 5th to 4th..no high rev or anything..
any help would be awesome..
Old Apr 22, 2010 | 09:49 AM
CrazyEye's Avatar
what i noticed was when i lay of the gas at about 45 50 miles per hour there is a crazy vibration, sounds like metal is running next to each other. when i hit the gas, the vibration goes away.
How about U-joints on the rear driveline??
Old Apr 22, 2010 | 09:54 AM
myyota85's Avatar
is drive shaft loose thats what mine did????????
Old Apr 22, 2010 | 09:56 AM
Myron's Avatar
totally bypassed the drive line..i did not disconnect the drive l shaft/line at all..but ill take a look this evening..
Old Apr 22, 2010 | 11:41 AM
allnmstkn313's Avatar
U-Joints, Alignment, Tire balance, Rear Differential.
Should be one of em.
Old Apr 22, 2010 | 01:34 PM
Myron's Avatar
alignment is good, tire balance is good..i might need to drain and refill rear diff fluid.
Old Apr 22, 2010 | 01:37 PM
yoder519's Avatar
my tranny was soundin liek a can of spoons on the freeway. threw in a Marlin Crawler clutch, problem solved my friend
Old Apr 22, 2010 | 02:12 PM
Yeah, not the fluid the differential itself... But do check the u-joints first.
Old Apr 22, 2010 | 02:30 PM
Stuwy123's Avatar
Sounds like a driveline issue.
U-Joint more than likely.
Do you grease your driveline with every oil change?
A $10 grease gun will save you from buying $40 u-joints.
Old Apr 22, 2010 | 03:46 PM
Myron's Avatar
Mine sounds like the same thing...along with the vibrations..
ill check the diff..all i have to do is bolt of the one side of it right? like 8-10 bolts?
I dont grease anything, have a grease gun.
Thanks for the info guys..ill be checking those out later
Old Apr 24, 2010 | 08:23 AM
Lumpia's Avatar
IIRC you will have to pull the axles out of the axle housing in order to pull the diff out, I could be mistaken however. (This is the case with my 85 4runner.)
If you have jack stands you can hold up the back of the truck (so the wheels are off the ground). Then start the truck and put it in gear. Then investigate to see if you can figure out where the noise is coming from. Be careful in doing so, as there is some inherent danger to it.
Old Apr 24, 2010 | 02:13 PM
RobD's Avatar
I'm with the other guys and the U-joint issue. Mark where the rear shaft lines up on the transmission and rear diff flanges, drop it (8 bolts, takes a few minutes) then drive around in 4x4 (front wheel drive, really) and see if the noise goes away. Far easier than opening up your rear pumpkin.
Old Apr 27, 2010 | 09:09 AM
Myron's Avatar
okay guys, checked out the u joints and the drive line and everything seems to be intact. Did not grease the u joints. What i did notice was the passenger side drive shaft is gone. The CV boots are busted, and when i turn the drive line, the passenger side drive shaft turns. i don't think it should. I drive around in 2wheel drive only. but that could be the sound of metal rubbing against each other, but that doesn't explain the vibration that i get. any takes?
Old Apr 27, 2010 | 09:20 AM
desertcox05's Avatar
i also agree with u-joints
I suspected mine and tried to test them and everything seemed tight.
The roar got louder and louder so I went back and pulled the DS and low and behold the things were toast. 1 had no ball bearings left in it and it was worn half way through.
Old Jul 10, 2010 | 08:53 PM
4Ruster's Avatar
do you have manual hubs on your rig or is it add.i had a gen2runner with it and the fronts always spun.through on some warns and no more spin
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JPV
Sep 28, 2015 03:15 PM
Odin
Sep 26, 2015 06:56 PM
