My 3VZ-E Super Stock "Upgrade" Thread
Old Jan 27, 2011 | 08:39 AM
  #121
1styota4X4's Avatar
Originally Posted by 204runner
Sorry to hijack the thread but How the hell are you getting 250hp and barely loose to a audi must be something wrong with the car. the 3vze was rated at 150hp and 185ft/lbs from factory and I have yet to meet someone who has bolted on another 100 ponies.
enlighten me
Yes do tell my 95 with the 3.0 was decent but no where near 250hp...do tell
Old Jan 27, 2011 | 03:25 PM
  #122
myyota's Avatar
Have you ever considered doing an AFM swap ?, im sure you would see some gains from doing that.
Old Jan 28, 2011 | 03:59 AM
  #123
dieselloco427's Avatar
enlighten me
Yes, PLEASE enlighten us into how you obtained those numbers with a 3VZ-E.
I have not even thought about doing an AFM swap. Hadn't even crossed my mind.
Gas milage update: I took a trip to Richmond and back (about 180 mile drive round trip). Filled up with 89 octane before and after. I averaged 19.24mpg @ an average speed of 65mph. Not bad... I'm going to be doing the trip again soon. It will be interesting to see if that number holds, or if it's just a fluke...
Old Jan 28, 2011 | 09:00 AM
  #124
JR's Avatar
JR
To have 250HP it is not a stock 3vze could be built to 250HP though. I once saw a Toyota Pickup in Calgary Pick Your Parts that had a V6 motor and on the valve covers it said Heads by Yamaha, it also stated DOHC. Was looking for car parts. Apparently this motor put out 225HP but only 2000 where shipped to Canada or North America. Do not know if it was a modified 3VZE but it was a V6.
Diesel almost 20MPG with an auto is not bad, which way was the wind blowing. Presently I am getting 17 to 19 MPG (US) with 750 - 1000 pound load at 70MPH.
Boy do I wish we could adjust the computer.
Old Jan 28, 2011 | 12:25 PM
  #125
spainobain1234's Avatar
THis is how I g0t 250 hp. Follow the instructions on the forum "How to mod your 4runner". That should boost your hp minimum. FOr MAximum results,
Brand new crate motor, take it to the shop, have it rebuilt for performance (mine was built with bigger pistons, LARGE Cam, etc etc... ) Have it leak tested, timed for performance and Add a trustworthy performance chip that you would prefer... it takes research on which one to buy, HEaders, dual 3 inch exhaust, PLus K&N, Also find a mechanic that you know well because otherwise, you'll be getting less hp for more money...
Again my 4runner has been done up so find a 4runner without a engine and start there! LUCK
I am saying F these engines now, F the 3vz and go with a 320hp stock 2jzgte supra motor because ya you have to plug in the wiring harness, and take the bellhousing to a shop to be customized (R150F beginning of bellhousing cut in half and connected to 2jzgte ending of bellhousing cut in half) ( ) BUT 600 hp is cheap to come by after the engine is installed! GO 2jzgte
Old Jan 28, 2011 | 12:35 PM
  #126
Originally Posted by dieselloco427
So I'm still having some minor issues getting the idle set right. I started getting some pinging earlier today so I pulled over (just happened to have a timing light on me) and checked the timing. Well, the timing at idle (E1 & TE1 jumped) well above 25 degrees btdc. Of course it idled nice and smooth then - Now that it's back down to 10 degrees, I have a very low idle @400/500 rpm (even with idle screw open all of the way) and no power on accelleration. The TPS is set spot on and I don't seem to have any vacuum leaks. I'll see if I can borrow a smoke tester to confirm that. I suppose I'll also re check the AFM again.
Any other suggestions?
I really just want to pay for your 2jzgte SUPRA engine to be swapped in. NO more issues... 320 hp stock, But I am not rich. ONE DAy .
LOOK up the 2jzgte 4runner on youtube man its crazy sweet
Old Jan 28, 2011 | 02:01 PM
  #127
Greg_Canada's Avatar
Hey dude, sorry to burst your bubble, but you're definately not at 190 crank hp. Not anywhere close.
I'm going to say you're right at bone stock, 150hp.
I've seen stock dynos over 110hp.
Now, a stock 3.4 (185hp, 220lb-ft), makes anywhere from 145 - 160whp (2wd, 4wd, auto, 5spd, etc).
So basically, if you had the power of a stock 3.4 (185hp) you'd be making atleast 150whp.
(that's why i did a s/c'd 3.4 swap).
BTW spaino,
you're crazy, no way you can get 250hp out of a 3.0 on pump gas and with no turbo.
Old Jan 28, 2011 | 03:44 PM
  #128
BTW spaino,
Hahahahaha 150 hp STOCK I agree, but like I said, DOug thorley headers adds around 50hp, so roughly 190hp plus K&N 5 HP at 195HP PLUS PORTED AND POLISHED intake manifold PLUS LARGE CAM 14 HP BIGGER PISTONS, 3 Inch dualy exhaust with high output flow mini cat converters,
I haven't taken it to a dyno thats for sure, but I estimate my hp being beyond enough powerful or at least more powerful than many other rigs on the road. And the minimum it makes is 200 at the crank.
Old Jan 28, 2011 | 04:26 PM
  #129
tpaine14's Avatar
250 is a big claim. just sayin.
Old Jan 28, 2011 | 05:18 PM
  #130
T_F_E's Avatar
50 hp from headers??? have you been playin to much need for speed?
Old Jan 28, 2011 | 08:13 PM
  #131
toy4whatever's Avatar
Sorry guy, but there is no way your getting 250hp out that 3.0. You cant just add up the HP that each bolt on claims. It doesnt work like that. Yeah you might have more internal work but I'm still waving the flag on 250 HP.
Old Jan 28, 2011 | 10:14 PM
  #132
On the other hand
Hahahaha K dudes I think Everybody needs to start swapping in some 2jzgte's and shocking other drivers on the road with 320hp. Because Our 4runners are gutless.
Old Jan 29, 2011 | 10:11 AM
  #133
tpaine14's Avatar
i put some fuel injection cleaner in my truck today. bottle says it can make my truck more responsive...im estimating about 300 whp.
Old Jan 29, 2011 | 05:43 PM
  #134
stomper4x4's Avatar
Yeah so? I put octane boost in mine, you're so toast.
Old Jan 29, 2011 | 06:27 PM
  #135
hunter4runner's Avatar
you've have too much
Old Jan 29, 2011 | 06:30 PM
  #136
tpaine14's Avatar
ugh...fml
Old Jan 30, 2011 | 09:59 AM
  #137
Runner491's Avatar
HAHAHAHA
50HP from a set of headers? where did you learn how to work on engines? cooking school?
Old Jan 30, 2011 | 06:44 PM
  #138
KelleyC's Avatar
THis is how I g0t 250 hp. Follow the instructions on the forum "How to mod your 4runner". That should boost your hp minimum...
*I do believe you're talking out of your a..
Old Jan 31, 2011 | 04:14 PM
  #139
truckmike26's Avatar
I don't think he's being serious.
Old Feb 1, 2011 | 07:39 AM
  #140
kwnate's Avatar
troll...
