Morse Code Diagnostic Check?
Old Mar 7, 2007 | 03:34 PM
4x4countrygirl's Avatar
My check engine light has come on and I really do not want to pay someone to read it and the Autozone here can not read it either. Does anyone know how to do the More Code Diagnostic Check? I read my Haynes Manual and can not find it.
4Crawler's Avatar
Procure a high priced scan tool:
Then read them yourself:
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old Mar 7, 2007 | 04:11 PM
Chapman88SR5's Avatar
Wow I have never heard of that!
Isn't there a way to turn the key a certain amount of times to get the check engine light to start flashing?
Old Mar 7, 2007 | 04:13 PM
TNRabbit's Avatar
IT'S ALL ON THE LINK!!!
Old Mar 7, 2007 | 04:20 PM
I am not seeing it. All I see is him describing how to use a paper clip to do it. Which I will most likely end up doing (thanks 4crawler) but that is not what I am asking.
Old Mar 7, 2007 | 04:41 PM
TNRabbit's Avatar
Here's another link: http://www.off-road.com/toyota/tech/codes/
and cut/pasted from the above link:
Assembly and Use Instructions:
* Simply unfold the scan tool.
* Precisely bend the legs to match the spacing of the diagnostic connector terminals.
o Early engines label them T and E1, later models may list them as T and TE1.
* Shove it in.
* Then turn on the ignition (but do not start the engine)
* Read the flashing code(s) on the Check Engine light.
Notes:
* Once you have found the diagnostic test connector, just insert a short piece of wire or even a bent paper clip into the contacts and turn the engine on (do not start it) and read the code(s) by counting the flashes of the Check Engine light.
o Here is a good article on the procedure to the later '80s and early '90s pickups and 4Runners.
o And for the '85 and similar 22RE engines, this chart has the codes for the earlier ECUs.
* A sharp eye may spot a mysterious round valve handle in the lower left corner of the picture above. If interested in what that is, you can find out more on this page.
* The Circuit Opening relay is located in the passenger side kick panel/A-pillar area.
o It may be located behind/above the ECU module, behind/beside the passenger front speaker.
o It is a small black box, about 2" square, likely need to pull the glove box to reach in from above.
+ Also back there are the headlight reminder module (black box) and the wiper control module (green box).
o It is a fairly expensive part and is likely only available from Toyota.
And, after tiring of fumbling around for something to jumper either the diagnostics or fuel pump test connector, I came up with a very simple solution. Using a piece of aluminum angle, pop-riveted to the lip of the fender, I drilled a couple of holes to mount a pair of SPST toggle switches. A pair of wires from each switch runs to the approriate test plug and now it is a simple matter to flip a switch and pull the diagnostics codes:
Fuel Pump and Diagnostics Switches
Fuel Pump and Diag. Switches
NOTEs:
The switches are not stock, I ADDED them and the aluminum panel to mount them on.
You DO NOT have to do this, I'm merely showing what I DID!
Also the blue electrical box in the lower right corner is the control box for an on-board welder and that is not stock either.
I ADDED it.
Finally note that the blue box is located where the stock 22RE air filter box is located.
Mine has obviously been moved elsewhere.
Old Mar 7, 2007 | 05:02 PM
Again, not what I am looking for.
I KNOW there is a way to just turn the key a certain number of times to get the check engine light to flash a code. A mechanic friend did it and an AutoZone employee did it.
Old Mar 7, 2007 | 05:32 PM
TNRabbit's Avatar
Never heard of it.
Old Mar 7, 2007 | 05:38 PM
Someone has to. I don't need it now that I know another way, posted by 4crawler. I will just call AutoZone and ask tomorrow.
Old Mar 7, 2007 | 05:52 PM
Dan_90SR5's Avatar
I have no idea about the Runners and trucks, but I know that you could do what some refer to as the "key dance" on the '90-93 Celicas. I would assume that the Runners and trucks would be the same. I wish I could remember how to do it, but at least I've heard of what you're talking about.
I'll see what I can find and post if I find it.
Old Mar 8, 2007 | 05:26 AM
4Crawler's Avatar
That is what you do, insert the diagnostic jumper, paper clip or as Toyota callls it an SST (Special Service Tool) and turn the ignition on.
Old Mar 8, 2007 | 05:40 AM
Fergie's Avatar
If I remember correctly, you turn the key from off to run, off to run, off to run, and then read the codes.
I did this on my old Plymouth Breeze, and it worked just fine.
Old Mar 8, 2007 | 05:41 AM
So three times? I will try this later and see if it works. Thanks!
Old Mar 8, 2007 | 05:51 AM
Fergie's Avatar
Yup, three times.
Make sure you have a pen and paper handy to record the number of flashes.
Old Mar 8, 2007 | 08:22 AM
4Crawler's Avatar
Before ODB-II, different vehicles had different ways of accessing the codes. What might work in one make/model won't necessarily work in another (the three key turns doesn't work on my '85 - just tried it, maybe it works on the newer TCCS systems). That was likely one of the goals for the ODB-II systems, to make all vehicles compatible as far as on-board diagnostics go. I set my '85 up with a switch hard-wired to the diagnostic connector, that way, I just flip a switch and turn the key on to check for stored codes or to check the ignition timing:
Old Mar 8, 2007 | 09:19 AM
surf4runner's Avatar
Old Mar 8, 2007 | 10:27 AM
Just to clarify, there is NO WAY to turn the key X amount of times to get the code to flash.
You have to do what 4crawler posted above.
THANK YOU 4crawler is helped a bunch!
smthwsn357
May 1, 2024 07:28 AM
raptor510
Feb 17, 2017 07:11 AM
nonstop
Jul 24, 2015 06:29 PM
Sandman
Jul 14, 2015 12:36 PM
