Marlin Crawler Flywheel has a pit in it
Old Jan 29, 2006 | 07:12 PM
tjkwak's Avatar
I want to get some info/opinions.
I bought a Marlin Crawler resurface flywheel and clutch kit
off the classifieds.
While inspecting the flywheel by sight and touch
there is a small pit/groove on the flywheel.
The area is flat around the pit/groove.
Do you think this flywheel will be okay to install.
Thanks for your inputs.
Attached Thumbnails Marlin Crawler Flywheel has a pit in it-11.jpg   Marlin Crawler Flywheel has a pit in it-2.jpg   Marlin Crawler Flywheel has a pit in it-3.jpg
Old Jan 29, 2006 | 07:22 PM
F0RSAKEN's Avatar
Not 100% certain....but a pit that small shouldnt make any difference what so ever in the clutch/fly wheel performance nor durability.
Old Jan 29, 2006 | 07:43 PM
superjoe83's Avatar
dont worry about it
Old Feb 1, 2006 | 10:13 AM
phorensic's Avatar
Is the defect concave or convex? If it doesn't stick up past the rest of the surface then it shouldn't affect anything. Even if one of the sides of the defect stuck up I still don't think it would be a big problem.
Old Feb 1, 2006 | 10:16 AM
Albuquerque Jim's Avatar
If you are referring to the step that runs the whole way around. It's supposed to be that way. Toyota runs a stepped flywheel. There should be something like .020" step between friction and mounting surfaces. (don't quote the spec. I am not sure for your application)
Old Feb 2, 2006 | 12:03 PM
Eric's Avatar
that thing is fine
Old Feb 2, 2006 | 02:19 PM
brendonv's Avatar
Run it Tong~
Old Feb 2, 2006 | 02:21 PM
4x4Lamm's Avatar
Its all good. I always got mud with gravel in it in my old 92's bellhousing anyway.
Lamm
kawazx636
Oct 6, 2021 03:03 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
crash813
Sep 27, 2015 07:15 AM
Toys4parts
Sep 26, 2015 01:56 PM
