Manual truck radiator in a auto 4runner?
Old May 1, 2009 | 11:56 AM
drmix's Avatar
Exclamation Manual truck radiator in a auto 4runner?
Im looking to replace my radiator on my automatic V6 4runner and all I can find are V6 radiators for manual trucks. Will that work for me?
Old May 1, 2009 | 12:22 PM
DYNNOMMYTE's Avatar
you will have to get an auxilliary transmission cooler... as looping the lines will cause it to overheat...
Old May 1, 2009 | 01:00 PM
Marc's Avatar
Funny, it's usually the other way around.
Most places just stock the auto rad as it can be used in both.
Old May 1, 2009 | 04:51 PM
Flash319's Avatar
ABS and Non-ABS is also a difference. The ABS one mounts higher to clear the hydraulic lines.
Old May 1, 2009 | 05:09 PM
toyota4x4907's Avatar
Go to NAPA and get a new radiator that works with both manual and autos for less than $150.
Old May 1, 2009 | 05:12 PM
waskillywabbit's Avatar
Every 22R/E radiator (OEM) I've seen was for auto or manual.
Don't know about the 3.sucks.
Old May 1, 2009 | 05:57 PM
Are you talking about after market radiators, Wabbit? Because the factory radiator in my '93 didn't have the holes for the auto fluid.
Old May 1, 2009 | 06:02 PM
Every Toyota OEM radiator I have ever seen on a 22R/E has the auto tranny ports for the tranny cooler on the bottom. They are plugged on the manuals and obviously have lines attached on the autos.
That has just been my experience as with all the other things Toyota did/does it seems a bit wasteful to have 2 different radiators, but that might be the case.
I'm sure someone who has access could compare part #s to see when the difference does indeed start.
Old May 1, 2009 | 06:10 PM
Hmm...I know the radiator in my '93 didn't have the auto fluid ports because I was worried I had gotten the wrong radiator when I replaced the OEM one with one from NAPA (which had the auto fluid ports).
Old May 1, 2009 | 06:12 PM
Perhaps yours wasn't OEM.
Old May 1, 2009 | 06:16 PM
Mayhaps... The truck only had 87K miles when I bought it and the radiator looked far from new and it was leaking (took me 4 years to replace though) It was metal like the other OEM ones I have seen, so I am assuming it was.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
voiddweller
19
May 2, 2016 09:10 PM
vasinvictor
Jan 20, 2016 12:39 PM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
TheManOutside
Jun 18, 2015 03:32 PM
