Maf Sensor, Good Or Bad?
Old Nov 8, 2006 | 10:37 AM
YOTAKIMMER's Avatar
Ok, was just out working on the yota again and took a look at the maf. It is pretty crusty and when I move the metal flap inside the maf, it does not move smoothly. It is very hard to move and feels like it ratchets. Is it suppose to move smoothly and just feel spring loaded or is this how it is suppose to feel and be difficult to move?
Old Nov 8, 2006 | 02:31 PM
Flash319's Avatar
It should just be like pulling a spring then snap back. If not you got problems.
Old Nov 8, 2006 | 02:57 PM
mt_goat's Avatar
It's an AFM, not a MAF.
Old Nov 8, 2006 | 03:10 PM
Elton's Avatar
x2...
Old Nov 8, 2006 | 03:22 PM
YOTAKIMMER's Avatar
Guess I have problems then, because it opens very hard and clicks as it opens. So now I need a fuel pump and AFM...great.
Old Nov 8, 2006 | 04:05 PM
YOTAKIMMER's Avatar
Let me know if anyone has a working AFM for a 89 yota pickup with 22re they want to sell for cheap...I went from a free truck to $1200 plus into it...pretty much broke and it still isn't running.
Old Nov 8, 2006 | 04:15 PM
suprathepeg's Avatar
Isn't there some sort of fuel cut in the afm? It could be that the afm is the reason for both your problems. IIRC you can get a larger AFM for that engine that is plug and play from a supra, you'll have to do some research for yourself though.
Old Nov 8, 2006 | 05:01 PM
^VooDoo^'s Avatar
The supra AFM wont work, totaly different resistances and a CFM beyond what the 22re ECU can handle, You would also need to use the ECU for that particulare AFM since it was designed for a 6Cyl and comparible CFM.
First off, what engine and year do you have?, Knowing this helps alot.
"ALL" 3vze's use 22250 65010
22re 83-85 22250 35010 (celica)
83-88 22250 35020 (truck)
83-88 22250 35040 (22rert truck)
89-92 22250 35050 (truck)
All the 22re afm should be compatible to eachother with the 22rert one being the only one tuned different but I doubt that.
The reason for the different numbers is to help match with ECU's and thats because the difference in inpedence in the injectors and thats a different subject.
Old Nov 8, 2006 | 05:33 PM
dcg9381's Avatar
I'll have an AFM for you in a few weeks.
If the AFM is dead, don't count your fuel pump out yet...
Old Nov 8, 2006 | 06:07 PM
YOTAKIMMER's Avatar
This is a 89 toyota pickup with 22re in it.
Old Nov 9, 2006 | 09:00 AM
YOTAKIMMER's Avatar
What year afm's will work for my 89 22re?
Old Nov 9, 2006 | 04:45 PM
carova_kevin's Avatar
Definently don't assume your pump, The jumper wire trick will make the pump run while the key in in "on" position, even if AFM is not signaling the pump to run. This is the link:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
easy test, don't forget to check fuses.
Old Dec 23, 2010 | 11:28 AM
tankyota's Avatar
Reviving this old thread just to say that I just had this same problem and wrote up something on how to fix/inspect the AFM.
https://www.yotatech.com/forums/f116...nation-226336/
Old Dec 23, 2010 | 03:55 PM
InternetRoadkill's Avatar
That's a nice write up. But it didn't mention that you can remove the bottom plate to clean the vane and the air channel. They tend to get a little corrosion inside them over the years which can cause the vane to drag. Plus, with a little effort, you can replace the bearings that the vane pivots on (they tend to rust) and make it move like new again.
Old Jan 1, 2011 | 06:51 AM
tankyota's Avatar
Thanks, that's good to know. I assumed it was removable but three of the screws buggered up when I tried to remove them, so I couldn't get it off. Be very careful with the screws on the bottom.. they're like made of lead or something.
Old Mar 31, 2022 | 04:41 AM
bando's Avatar
22250-35020 vs. 22250-35040
Guys, I have an '89 4runner with the 22RE engine that needs a new mass air flow sensor.
The original part says 22250-35020, but does anyone here know if I can just substitute it with part # 22250-35040 without a problem?
Thanks in advance! Much appreciated!
Old Mar 31, 2022 | 05:50 AM
scope103's Avatar
This dealer https://parts.lakelandtoyota.com/pro...rm=22250-35020 says the part you have is for use w/o a turbo, 22250-35040 is for use with a turbo.
Other than the fact that Toyota saw fit to make two different parts, I don't know if they are interchangeable.
Jun 1, 2021 01:51 PM
smiley52
Jul 11, 2015 05:16 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
wilbertd
Jul 6, 2015 07:39 AM
