lockrite problem "clunking" "jerking" jerking need advice
ok i got a problem!!
installed it and drove detroit ez locker and drove up to Tahoe about 120mi round trip all highway. first, every few secs it would Bang then jerk me left or right. but the big problem is a few times a min it would BANG rev up, sometimes times 200rpm and jerk the truck BBBAD. is that normal, to me its un drivable and is going to brake something else, only does that over about 25mpg. im going to take it out if thats normal.
i have never been in a truck with a lockrite so i have no idea whats normal.
bolth tires spin in dirt now and unlock in parkinglots
i know this is NOT it but, felt like i sucked a bolt through the ring pinion.
the lockrite Manufacturer Part Number: 813a028
got off ebay!
even came with extra parts.... 9pins, 7 springs, few extra spring caps
i think i set the springs and pins up right. (ill post a paing shot pic)
thanks for the help yotatech
got off ebay!
[IMG]
[/IMG]
this is a stock photo from summitracing.com
see how there is 4 green circled spring ends, well i used 8, one on each ond of spring
im thinking there is too much tension, i have no clue if thats it tho. any one have any ideas?
[/IMG]this is a stock photo from summitracing.com
i have a lockright and mine doesnt do that ..
i installed mine a while ago and honestly dont remember how it all went together .
try this site there is lots of pics .
http://www.gearinstalls.com/
my have frt and rear lock rights in my 85 and every now and again after i go around a turn it it will pop (im assuming going back to normal position). What your describing seems like they are to tight.
i definitely am NOT suppose to use that extra spring cap look here
https://www.yotatech.com/forums/f116...locker-105471/
im just hoping thats it but idk
Doesn't look right at all. Can you send it back for replacement?
Also, Ive never had issues with unequal tire pressure. The lockrite reacts to tire slip.
Unfortunately it sounds like you need to pull the third again and check your assembly.
