Locked up engine
Old May 30, 2012 | 04:08 AM
blake.nemitz's Avatar
if you swapped flywheels, who knows maybe its not the same thickness at the mounting point. i cant think of anything besides that that would effect the operation of the motor doing a simple clutch job. even the disc in backwards if possible to even mount the pressure plate most likely wouldnt cause this. im curious to what it is when you find out
Old May 30, 2012 | 04:10 AM
xxxtreme22r's Avatar
Right and that's similar to the problem I had and I had to shave down or find shorter headed bolts (the ones that hold the plate onto the back of the motor) that didn't hit the flywheel. If I didn't spin the engine after I put the flywheel and pressure plate back on, I would have never noticed it.
Old Jun 12, 2012 | 08:39 PM
ktm250exc250's Avatar
It's All fixed now! turns out that the bolt that holds the metal plate behind the flywheel on had a washer on it which made it stick out too far and caused the flywheel to be basically locked in place. Ill upload pics asap
Old Jun 12, 2012 | 08:52 PM
And that was my initial thought. Only in my case I was using the correct bolts. Glad it was an easy fix.
Old Jun 12, 2012 | 09:02 PM
  #25
I was also using the corret bolts ...i just dont know why i put that lock washer on it. Oh well.. you live and you learn
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
mengquis
Jul 13, 2015 10:39 AM
Johntom240
7
Jul 13, 2015 12:18 AM
AaronM
Jul 8, 2015 07:15 PM
