little bit of water almost kills truck
Old Dec 12, 2006 | 09:15 PM
basinredneck's Avatar
when ever i get the engine wet at all it freakin almost dies i can be in first and it will act like 5th. there was a little mud in the airbox last time. After about 15 to 20 minutes of barely running it gets better. what should i do to get it to stop?
Old Dec 12, 2006 | 09:22 PM
ChickenLover's Avatar
It sounds like water may be getting inside your distributor somehow. What engine are we talking about.
Old Dec 12, 2006 | 09:24 PM
it has the little 4 banger
Old Dec 12, 2006 | 09:32 PM
SLC97SR5's Avatar
How about some specifics. Is this a Tacoma with the 2.4? Or is it older like a 22R? Give us all the info you can and we'll help from there.
Old Dec 12, 2006 | 09:36 PM
sorry its a 1994 reg cab short bed pickup, it has the 2.4, i don't know the difference between the 22r and 22re, i bought truck 2 months ago, before then it was 460 and bronco, totally different worlds.
Old Dec 12, 2006 | 09:43 PM
Elton's Avatar
22r has a carb 22re is fuel injected
Old Dec 12, 2006 | 09:44 PM
oh thanks, it's the re then.
Old Dec 12, 2006 | 09:50 PM
SLC97SR5's Avatar
It sounds like H20 is finding its way inside your distributor and maybe the ignition coil. Are your plug wires original?
If so, they are probably arcing against each other and that's causing your problem.
Since it's cold now you may have some condensation freezing overnight on your distributor cap. Remove it and spray it with some WD-40, then dry it out with some towels or compressed air.
Old Dec 12, 2006 | 09:53 PM
i'm pretty sure they're original, i got new plugs today i'll get new wires tomorrow, why not. THANKS.
Old Dec 12, 2006 | 10:06 PM
SLC97SR5's Avatar
Make sure to get the good stuff...ie no champions, autolites or bosch. Get some NGK or DENSO plugs and OEM wires. If you can't get the OEM wires a good set of aftermarket should do.
While your at it how about a new cap and rotor? Also, sometimes the rubber boot for the D-cap can trap moisture not allowing it to evaporate.
Old Dec 12, 2006 | 10:16 PM
The plugs i got are NGK. Only ones they had anyway. I'll see what kind of wires i can get tomorrow. I'll try and get the cap and rotor too, thanks man.
really, thanks. guttin out in a decent sized pit would suck.
Old Dec 12, 2006 | 10:19 PM
SLC97SR5's Avatar
Right on, pick up a packet of the di-electric grease they usually sell at the counter and smear a dab on the ends of the plug wires where they contact the plugs and the cap.
Anything you can do to help waterproof helps.
I know how UT guys wheel!
Old Dec 12, 2006 | 10:28 PM
sounds like experience to me.
they gave me a little packet of something like that when i bought them but i don't know if it's that stuff or not. hope so.
Old Dec 12, 2006 | 10:36 PM
SLC97SR5's Avatar
It could be di-electric grease but It's probably anti-seize for your plugs.
If it doesn't say then you can ID them.
Di-electric: White or clear, sometimes a brownish tan sticky, sticky grease. Very smooth.
Anti-Seize: Gray, silver or copper colored. Sparkly from the powdered metals suspended in the grease. Very fine, slightly gritty consitency.
Old Dec 12, 2006 | 10:45 PM
i don't know it's out in my truck right now i bet it says right on it what it's for.
thanks.
Old Dec 12, 2006 | 11:15 PM
bob200587's Avatar
Also consider putting some gasket maker on your distributor. I've done it before and it's not difficult to remove, but still keeps water out.
Old Dec 13, 2006 | 10:06 AM
drew303's Avatar
distributor.
voiddweller
19
May 2, 2016 09:10 PM
93handmedown
Jun 19, 2015 06:26 PM
Dennis140
Jun 17, 2015 10:37 AM
Toddski
Jul 19, 2002 10:47 PM
