Leaky Fuel Injector?
Old May 21, 2009 | 12:43 PM
Azca's Avatar
Angry Leaky Fuel Injector?
I found my fuel leak, it is an injector and unfortunately I discover this AFTER I replaced the valve covers about 6 weeks ago! So here is my question, when I pull the fuel rail to get to the injector, do I have to monkey with the other two? Oh yeah, it is a 3.0. As darned expensive as these things are I would rather not replace them and would like to save what $ I can for a motor swap that hopefully will be done next year. The motor has 215K on it and looks like I may have the beginnings of a rear seal leak. I will not fix the leak, I will just swap in either a 3.4 or 4.0.
Any sugestions?
Old May 21, 2009 | 01:07 PM
MrPeepers's Avatar
If it's just the o-ring that should be a cheap fix. If it's the injector itself, ther eis a place in L. A. that if you send them in, they would rebuild and "dyno" each injector for $25 last I checked. They are so good that even on a newer car, you can see performance gains, getting all the injectors tuned to spec and matching, instead of the normal method of them just being thrown on.
Old May 21, 2009 | 03:15 PM
DJ99's Avatar
You have to take the intake off to get to the injectors. The intake gasket is only like $4 bucks at NAPA. You can replace all 6 of your injector seals for about $26 with the Mr. Injector kit off ebay. It's worth $30 bucks at that mileage.
Old Jul 23, 2010 | 06:52 AM
tblake88runner's Avatar
I am dealing with exact same problem. I bought the intake manifold gasket from Checker. I came with all the gaskets, $62...grrrrr. I replaced all the oring in all 6 injectors. The middle injector on the right side is still leaking. It is either mis-aligned, the injector itself is leaking, or the injector rail has a bow in it.
Old Jul 23, 2010 | 10:33 PM
Armalite's Avatar
I had the same problem after i replaced my injector seals. The seals didn't fit tight enough on 2 injectors so i put hylomar on the seal and it quit leaking. I would be carefull not to get hylomar in the fuel and have it clog the injector.
Old Jul 24, 2010 | 12:32 PM
Thanks for the suggestion. I will try doing that this weekend.
Old Jul 24, 2010 | 12:41 PM
2DoorRunner's Avatar
http://www.witchhunter.com/
Old Jul 24, 2010 | 12:47 PM
92 TOY's Avatar
Originally Posted by 2DoorRunner
ditto on that.
although i saw a grrrr for $62 and mine cost (4 injectors) $105 plus shipping, but they , and my cold start injector came back tested and like brand new.......so that is something i know i am not going to have to mess with again for a long time.
doing a 3vze right now and the plan is to send 6 injectors and the cold start injector as well.
Old Jul 27, 2010 | 08:41 PM
zekesan's Avatar
I just had my old injectors replaced and 1/3/5 injectors keep blowing the o rings any thoughts ? do I need o ring at the grommet end as well as top end?
Blamalam
Mar 12, 2022 07:34 AM
RatOmeter
Oct 22, 2015 03:17 PM
Tacoma1313
Aug 17, 2015 05:44 PM
pyramid
Jul 30, 2015 10:05 AM
HookahRoo
Jul 20, 2015 07:06 PM
