leaking coolant
leaking coolant
so the other day my 4runner started to leak coolant from the left side of my engine and i have been putting more and more in... i cant seem to see where its leaking from? i took of the skid palte and moved the stabilizer because it was dripping over that... any ideas what it is... water pump?
left side as in drivers side? Could be coming from the water pump inlet/outlet deep in behind the alternator... the gasket cracks. Get some Barrs Stop Leak, I bought the block seal, it seals all major gaskets, etc and it worked great.
DO NOT use stop a leak crap. I used it once. Fixed my leak for like 3 weeks, then I was fishing out all that crap with a chopstick. Then my radiator had a catastrophic failure......
when describing 'left' or 'right' when talking about anything on a vehicle, please give a reference point such as the intake side, or exhaust side, or 'on the left when standing in front of the truck, looking at the engine' or similar.
Saying simply either "left" or "right", or "driver's" or "passenger's", doesn't mean diddly since we don't know where you were standing, etc. or if you have left or right hand drive.
Jason
My best guess would be the water pump. There isn't really much else that's going to leak like that on the passenger side. Time to do the timing belt & associated stuff too as long as you're in there.
your mystery leak sounds like the exact same one that I had on mine.. Mechanic found it to be the Heater Core and since it is summer right now, I dont need heat, so he took the lines off and hooked them together, waa laa, leak is gone.. I would check the heater core!!
Blamalam
Mar 12, 2022 07:34 AM
WellsR
12
Jul 31, 2015 03:27 PM
TJWilly
Jul 31, 2015 02:05 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
