knock sensor question.
If your vehicle is supposed to have a knock sensor then it would be more difficult to trick it than to just put one on.
The knock sensor has a piezo electric element that gives off an A/C voltage signal proportional to the vibration it recieves. it is tuned harmonically to the frequency of detonation ( about 7.1Khz) and at that frequency the amplitude of the signal increases tremendously. so if you where to build a A/C frequency transmitter and dial it in to the proper amplitude and frequency that would probably do the trick.
But like I said before, it would be a lot easier to just replace it.
I purchased a used one off Ebay. Worked like a champ. I drove my truck for awhile without one and it ran fine but turned on the CEL ever time I would drive off.
Now go get one and protect your motor. Ever seen a piston with a hole through it caused by detonation? I have. Failed right in the center where the little dimple is located. Detonation can also beat the he!! out of your top rings.
You can locate it here as indicated:
http://www.lcengineering.com/TechNotes/TechNote21.htm
Note, There at least 2 different KS designs - make sure you match thread and KS design to your ECU.
alright, thanks, i've got the tap for it already too, i'll be doing this tomorrow.
djohnson13
Sep 4, 2015 12:35 PM
Flossy
Aug 5, 2015 05:14 PM
