Katie's 3VZE head gasket job!
Old Apr 18, 2007 | 02:27 PM
  #201
aviator's Avatar
are you fresh coffee and home made cookies nice?
Old Apr 18, 2007 | 02:44 PM
  #202
justinking060310's Avatar
Well, I don't make it over there in the morning's but I do take em Gatorade and Beer in the afternoon's -- Does that work?
Old Apr 18, 2007 | 02:51 PM
  #203
TNRabbit's Avatar
Sorry to hear of your loss from the VT ordeal, Kat. Luckily, no one I know with kids going there experienced a loss; one of my coworker's kids had left one of the classrooms an hour before the shooting started. Another stupid tragedy....we really need to figure out what the h@ll is going on with our youth....
Old Apr 18, 2007 | 03:43 PM
  #204
I've decided that teachers should be allowed to carry handguns
Old Apr 18, 2007 | 03:49 PM
  #205
shoes138's Avatar
nothing is going on its just stupid people that ruin it for everyone and they giving us young peps a bad name!
Old Apr 18, 2007 | 04:03 PM
  #206
TNRabbit's Avatar
I LIKE how you think!!
Old Apr 18, 2007 | 04:17 PM
  #207
foot0069's Avatar
Katie so sorry to hear about your friends. Now we will add you to our prayers.
But on a lighter note just saw you weregonna get the little rubber gizzs for the injectors. I would recommend using new Toyota o-rings as well I used the ones that came in my rebuild kit and had leaks. Had already replaced the insulators with Toyota parts before I started it up and the leak scared me with that open header without the collector on it belchin all them flames. The new seals were the answer. No more fire allowed for you. I'm sure you have had more than enough of that.
Jim
Old Apr 18, 2007 | 04:35 PM
  #208
lol - I had Rich at Cruzin Performance rebuild them, so I wont touch them and if they leak, I will take it up with him. I am pretty sure he won't steer me wrong. Everything else on this motor is factory parts thou(minus the stuff from EB)
Old Apr 18, 2007 | 07:48 PM
  #209
TNRabbit's Avatar
Hey Katie--Look what I found:
nunsa
Knock sensors - Back in the late '90's we used to do recalls for the HG recalls on the 3.0's, It got to the point that most of the ones that we did would be back within a month or sooner due to a Code 52 "knock sensor", after Toyota addressed the situation whenever we did a HG we also replaced the knock sensor. So listen up: Whenever you remove the heads from a 3.0 to do a HG or whatever, Always, Always replace the knock sensor!
__________________
The Master Toyota Tech,
2003 Toyota Tacoma xtra-cab, 3.4 V6, 5speed,4x4, TRD w/OffRoad Package.
"Expert on the 3.0 Engine!"
Disclaimer: As a former TOYOTA TECHNICIAN I authorize this post/reply US MARINE*** SEMPER FI
Old Apr 18, 2007 | 07:50 PM
  #210
Bumpin' Yota's Avatar
and replace the KS wire!!!!
oh here's a pic of the little device I used to aresolized about 6 cups of gasoline during the cleaning of my transfercase cooler.
Old Apr 19, 2007 | 02:25 AM
  #211
Bumpin' - That thing looks useful - If used safely, that is a valuable item.
TNR - Thanks, I needed that, just one more thing to add, right? you just had to do it, didn't ya!
FINE, ill order it~
Kat
Old Apr 19, 2007 | 03:38 AM
  #212
TNRabbit's Avatar
"TNR - Thanks, I needed that, just one more thing to add, right? you just had to do it, didn't ya!
FINE, ill order it~"
I wonder if we could do a group order for everyone on the forum & save some bucks....?? :-)
Old Apr 19, 2007 | 05:28 AM
  #213
mt_goat's Avatar
Here's a few places that have good discounts on OEM parts:
http://www.trademotion.com/partlocat...?siteid=214074
https://www.1sttoyotaparts.com/partscat.html
Old Apr 19, 2007 | 07:00 AM
  #214
aviator's Avatar
well it ain't coffee and cookies but it will do...
Old Apr 19, 2007 | 07:06 AM
  #215
aviator's Avatar
too many rights is whats the problem I think... when we were kids we lived in fear of our dad's belt/boot, the strap at school, or the cops now they know you can't say boo to them... this leads to young adults with impulse control problems...
also we can not lock up people when they present "problems" without their consent... unless you drop a dime on them with HS that is...
  #216
TNRabbit's Avatar
By the way, found the knock sensor for $115 here: http://www.trademotion.com/shoppingc...6catalogid%3D1
Old Apr 19, 2007 | 02:00 PM
  #217
Ok, I have been working with Shannon Brookshire over in the Vendor Forums so I stuck with him and he does well for me.
I ordered:
Knock Sensor for $123
6 Injector Spacer's @ $6 each
A case of oil filters(10) for 32.90 for the case
SO, I am going to call the machinist tomorrow and see if i can get the long block together this weekend( at least far enough to wait on the KS)
KAT
Old Apr 19, 2007 | 08:08 PM
  #218
toyota_mdt_tech's Avatar
TNR - electrolysis is what we are doing just like you saw... I put the fuel filter bracket in there and left it overnight just to test the system -- I am now wondering if an LCA will fit in my 5 gallon bucket hmmm...
GOAT - I have one of these pressurized sandblaster but it isnt working worth a crap - I am about to return it -- I cant get flow consistant - I tried using play sand(bad idea) - cleaned out the system and tried 150 grit sandblasting sand(still didnt work) and most recently i bought the expensive stuff(black beauty) and still nothing
I don't know. we check the hoses and they are not clogged, neither is the deadman valve - we fiddled with the switch on the bottom of the tank.. nothing... pressure is definitely there...
kat
Kat, use "silica sand", but wear a respirator. And make sure it has a small screen on the inlet. A lump of sand will plug it up quick like! Make sure pressure is way up. It needs to have a "minimum" of about 100 PSI to work, under that, nothing will flow. Kat, I have been reading your thread, nice work! If I wasnt happily married, I'd ask you if you had any sisters!
Old Apr 19, 2007 | 11:34 PM
  #219
Just Learning's Avatar
ya, good work good thread, and dont forget post them pics
Old Apr 20, 2007 | 11:48 AM
  #220
No sisters for me Only a little brother
I talked to the machine shop this afternoon and he broke one of his carbide cutter-somethingorothers that he needs to do the 3 angle valve job, so he got his new one in today and will have my heads done early in the week. The block and everything is ready to go, but i opted to get some more prep work since it appears that we have a nice sunny weekend ahead of us!
I am getting off this computer to go get some work done -- I'll be back later
Kat
PS Thanks for the tips about silica sand - When i am feeling patient i will try again
