Just blocked off my EGR....
Old Jan 7, 2008 | 07:33 PM
  #101
1990Runner's Avatar
i just plugged the vac line and kinda sealed the hole on the egr valve to keep from getting trash in it.
Old Jan 7, 2008 | 08:40 PM
  #102
gametom's Avatar
is it the same to block it off on the 22re i did a search and found nothing usefull
and what are you doing with the vac lines? or do you just plug them
Old Jan 7, 2008 | 08:45 PM
  #103
Jay351's Avatar
Plugged it, and left it where it was. Truck is running smoother, this is my new favorite mod!
Old Feb 19, 2008 | 09:02 PM
  #104
1990Runner's Avatar
i guess that differant trucks get differant results, but i seem to have had a milage decrease over the last month with mine disabled. im going to hook the vacuum line up and see if my milage goes back up. ????
Old Feb 20, 2008 | 11:49 AM
  #105
Jay351's Avatar
I have mine hooked up, bypassing the non working EGR modulator. I can notice a little stumbling and a little less power. I can't wait to fix my smog issue and unhook it again.
Old Feb 25, 2008 | 09:35 AM
  #106
DBrooks's Avatar
Well I blocked off the EGR valve and noticed an immediate gain in power. I'd say 80% improvment in the engines proformance. Only issue now is that the engine seems to crank over alot before it fires and then starts. It has always fired and started fast. Do you think that the timing might have to be tweeked ? Thanks for all the usefull info provided on this forum!
Old Feb 25, 2008 | 01:34 PM
  #107
Booosted Supra's Avatar
I just did this to my truck, best 99 cent and 1 hour time upgrade on this motor by far. I just cut out block off plates for the exaust manifold and the upper plennum out of steel i had laying around. Now i was reading some stuff about the cold start injector, does that have to unplugged for part of this? or were we talking about 2 seperate subjects
Old Feb 25, 2008 | 01:37 PM
  #108
Jay351's Avatar
They are talking about two different things. Leave the cold start injector in place, unless its sticking it won't cause any problems.
and let me post again.. I hate my egr. Stupid hesitation and stumbling is back.
Old Feb 25, 2008 | 01:48 PM
  #109
yotasavg's Avatar
man i really gotta do this mod....so if i got it strait, all i need to do is plug the hose and leave it? or do i have to do the block off plate?
ps. how do i tell if my EGR is sticking?
Old Feb 25, 2008 | 01:50 PM
  #110
Jay351's Avatar
Test it by putting it under a vacuum, as per the FSM.
Yes just plug the hose and you're done (to an extent) If you don't have to get smogged, remove the intire EGR assembly, clear some of that engine clutter up.
Old Feb 25, 2008 | 01:54 PM
  #111
yotasavg's Avatar
i gotta get it smogged.........what do you mean to an extent? what are the benefits of doing the soda can block off vs. just plugging the hose.
Old Feb 25, 2008 | 02:12 PM
  #112
Jay351's Avatar
I belive if the EGR is stuck it will continue to blow crap into your intake. BUT don't take my word for it. I belive sombody told us the real reason eariler in the thread.
Old Feb 25, 2008 | 03:20 PM
  #113
yotaman8819's Avatar
can u put a picture of the motor after you blocked off the egr so i can get an idea of what to do to mine thanks
Old Feb 25, 2008 | 05:25 PM
  #114
jason191918's Avatar
Any Questions?
Old Feb 25, 2008 | 06:17 PM
  #115
JonnyBoy's Avatar
K, so I did this(plugged the vacuum line) and have driven around 30 miles or so...coolant temp has actually gone down some. Not much, but I'll update more after a tank or two.
Old Feb 25, 2008 | 06:26 PM
  #116
The temp difference due to the EGR should be the combustion temp, not the coolant temp.
Old Feb 25, 2008 | 06:48 PM
  #117
JonnyBoy's Avatar
True, but if combustion temp is higher, the coolant temp would be higher. Or am I oversimplifying?
Old Feb 25, 2008 | 07:03 PM
  #118
Makes sense, but I was told otherwise. Anybody else want to chime in?
Old Feb 25, 2008 | 07:09 PM
  #119
JohnnyRanger54's Avatar
This should be in the FSM!!! LOL
Old Feb 25, 2008 | 07:55 PM
  #120
wait so i did all that in the pics above, in pic number 3, i plugged off the hard line coming directly off the EGR, the EGR looking thing next to the power steering with the vaccum line gets blocked off to? cant i just take that part out then?
