Just blocked off my EGR....
Old Nov 24, 2007 | 05:37 PM
  #61
84sr5yoty's Avatar
Originally Posted by ovrrdrive
Have any of you guys that have bypassed the egr noticed any more pinging?
Yes, especially during the summer time. I bypassed mine because my idle was choppy and I did everything under the sun to fix it. I really need to get a new EGR valve and be done with it but since I only put less than 1000 miles a year on it these days, I probably won't bother until it's time to get it smogged again.
Old Nov 24, 2007 | 09:46 PM
  #62
Ganoid's Avatar
Another tip on the EGR is to decrease the size of the outlet for the exhaust allowed into the manifold. I just haven't had any motivation to do this myself.
Old Nov 25, 2007 | 02:06 PM
  #63
jtlinna3vze's Avatar
[QUOTE=MudHippy;50676927]
If you have an issue it will be with the EGR temp sensor if yours has one. You can install a resistor to replace it though. If you don't your computer will fuss at ya till ya do and probably screw up any performance gains you'd be getting too.QUOTE]
any picks of said resistor installed??
Old Nov 25, 2007 | 06:58 PM
  #64
MudHippy's Avatar
Originally Posted by LS1Steve
most likely 71, egr temp
just got back from radio shack, threw in a 10k resistor across the egr temp sender connector, engine light GONE
I haven't done it, mine don't have one.
Ask LS1Steve, maybe he does.
I imagine it's pretty straight-forward. Remove EGR Temp Sensor, put resistor between the 2 wires. Done.
Old Nov 25, 2007 | 09:48 PM
  #65
am i correct that since i didnt remove my egr just blocked it off at the intake manifold that it shouldnt throw an egr temp code? or is it going to over heat and throw the code?
Old Nov 26, 2007 | 02:32 AM
  #66
ovrrdrive's Avatar
It only throws the code if you remove the sensor.
My sensor is going bad and gives me the code for it, but I just haven't gotten around to unhooking it yet and installing a resistor in its place.
If it's still there it's still working.
Old Nov 26, 2007 | 08:51 AM
  #67
fire5's Avatar
Where would the EGR temp. sensor be; on the ECU?
Old Nov 26, 2007 | 01:06 PM
  #68
MudHippy's Avatar
Looks like it'd be somewhere after the valve on the pipe that feeds into the plenum chamber. Probably got a little 2-prong connector plugged onto it. That wire(s) goes to the ECU.
Old Nov 26, 2007 | 02:21 PM
  #69
nate V's Avatar
The egr temp sensor comes right out of the side of the EGR.....
It should be pretty obvious to where it is. It is the only wires coming out if it.
This should help
[IMG][/IMG]
Old Nov 26, 2007 | 02:48 PM
  #70
BrunswickYota's Avatar
Well, I just got done making the "gasket" and putting it on. Ran all around town today and I have to say, I didn't believe it but it did actually make my rig run better, better driving and darn if it didn't give me a little more pep? I don't know how or why but it makes my rig seem like it is responding to the petal better.
thanks guy
Old Nov 26, 2007 | 02:59 PM
  #71
TC4RNR's Avatar
would someone post a write-up for us snobs?
Old Nov 26, 2007 | 03:03 PM
  #72
Haha, I second that motion....
Old Nov 26, 2007 | 03:04 PM
  #73
We got us a real YotaTech mod shop going on here now....lol
Old Nov 26, 2007 | 03:19 PM
  #74
MudHippy's Avatar
You got the V6 so between this thread, and this one here with more pics, you should be able to figure out the gist of it.
Old Nov 27, 2007 | 01:04 PM
  #75
TC4RNR's Avatar
may i ask, where the heck is "cold start injector", and how to disconnect it? living in Curlyfornia, cold morning is no prob.
thanks.
Old Nov 27, 2007 | 02:14 PM
  #76
thanks.
if you scroll up and look at the pick of the egr.. youll see the black square pigtail that is connected to it..
Old Nov 27, 2007 | 02:21 PM
  #77
MudHippy's Avatar
thanks.
Unplug the connector(female black rectangular with a wire clip that snaps over tabs on sides of the male end)at the top of the unit. This will disable it.
It's not gonna help anything with it unplugged. Unless the cold start time switch is shorted/malfunctioning and causing it to spray when it shouldn't.
Old Nov 28, 2007 | 09:14 AM
  #78
TC4RNR's Avatar
i unplugged the cold start injector wire this morning and started the motor not having any problems. since i have a fresh tank of gas, i'll see if there's any MPG chances in the next few days.
Old Jan 2, 2008 | 08:56 PM
  #79
neoworm0's Avatar
Just wanted to add that I disconnected my EGr last week and put the 10k ohm resistor in. Wow does my truck ever run smooth now. My gas mileage went WAY up too. So far I don't see too much reason to reconnect it.
Old Jan 2, 2008 | 10:37 PM
  #80
Jay351's Avatar
Can you convert it back for aircare?
If so, this sounds like somthing I want to do
