Just blocked off my EGR....
Old Jan 9, 2010 | 10:36 PM
  #181
fissure333's Avatar
i bought a cal toyota for the prospect of future smog regs. that gas temp sensor on the top of the egr @ the upper intake can evidently be fixed. from what i understand you go to radio shack and buy a $1 pack of 5 pieces of 10k ohm resistors. simply unplug the thing and jump the connection. problem solved. i am going to remove that thing from the egr and thread in a bolt. that gas temp sensor is almost 2 bones for the cheapest one i could find. f that. i just want my check engine light to stay off for once.
as for the egr block off, i've been hearing about people doing that for as long as i can remember using a cut to form soda can or the like. i'm tired of all the carbon build up in my plenum so i think i might just go ahead and block 'er off.
Old Jan 15, 2010 | 05:49 PM
  #182
Culpeper's Avatar
Is it a 1k or 10k ohm resistor used to bypass EGR temp sensor? I've references to both in this thread.
Old Jan 16, 2010 | 03:40 AM
  #183
smarvin's Avatar
I think i i got the 10k but then there was a choice of 2 and i got the fatter ones.
Old Jan 16, 2010 | 10:01 AM
  #184
Culpeper's Avatar
thanx
Old Jan 19, 2010 | 08:47 AM
  #185
Blue_petersen77's Avatar
Just getting kneedeep in it. Some one should have told me how long that pipe is. I thought it would pull out east and just be a small flanged pipe... It's not, it's about 6 inches long and won't pull all the way out. I'm also replacing the pcv valve while I'm in that area. Make sure when you're blocking off the egr to have a hack saw on hand
Old Jan 19, 2010 | 09:47 AM
  #186
ibeamtaco's Avatar
hey just some info for people with smog laws at least in Cali i have my egr blocked of but you have to leave the hole system in truck to pass visual test and i dont know why but still no ck light and it sniffs clean but i do get it good and hot before smog and i run a soppy water solution threw vacuum lines to clan top end and i have a smog machine at shop and this drastically lowers nox
Old Jan 20, 2010 | 05:12 PM
  #187
Don't know about the 22re but my 3.slow just got a major kick in the can after blocking it off. The difference is a slightly lower idle. I was still having a dugong problem but not after the sea foam treatment! That stuff is a godsend! I now have a smooth very low idle and that surging problem is non-existent anymore
Oh btw reffering to the code 71... It happened with mine after the egr block... I didn't use the resistor trick. I just pulled the efi fuse for about ten minutes and I'm not throwing the code 71 (or any other codes for that matter) anymore
Old Jan 20, 2010 | 07:35 PM
  #188
Culpeper's Avatar
Keep an eye on the CEL because after you reset the computer it make take a day or two if the problem still exists. The code 71 that is.
Old Jan 20, 2010 | 08:08 PM
  #189
Will do. If it pops up again I might have to put on a resistor cuz nothing is more annoying than a cel. Especially the ones that come on some days then off on the other days lol
Old Feb 15, 2010 | 11:21 AM
  #190
Thumper_383's Avatar
Talking
Yep Yep! I live in Southeast Texas. When hell gets cold in the winter the Devil vacations here cause its so darn hot. Well guess what....its freezing here right now. NO GLOBAL WARMING!!! Yay!!! We're all gonna live.
Old Feb 15, 2010 | 11:24 AM
  #191
874runnersr5's Avatar
mines gone, i love it.
Old Feb 15, 2010 | 12:15 PM
  #192
Culpeper's Avatar
I did the .99 cent radio shack mod.....
Better performance and no more CEL.
Old Feb 15, 2010 | 12:29 PM
  #193
hunter4runner's Avatar
I did mine and it was functioning properly and I saw and felt a major difference
Old Feb 15, 2010 | 12:42 PM
  #194
fissure333's Avatar
the $.99 radio shack 10k resistor "the fatty one" is working GREAT! its been over a week now and no CEL.
Old Feb 15, 2010 | 04:10 PM
  #195
radio shack 10K resistor 1/4 watt 99¢ for 5
Old Feb 21, 2010 | 06:27 PM
  #196
devinscout's Avatar
Thumbs up
Blocked mine off this weekend, and now my truck idles smooth as silk.
Old Mar 1, 2010 | 08:04 AM
  #197
dfarr67's Avatar
Man there is alot of crap on this thread....I get the impression that if your truck is running good- egr is a non issue?
Old Mar 1, 2010 | 09:23 AM
  #198
yes that is true, mine worked fine but I wanted to block it off anyway and It did help with MPG
Old Mar 1, 2010 | 09:44 AM
  #199
vandert's Avatar
Mine ran like crap, did the usual suspect's first, TPS, cap, rotor, plugs, plug wire's etc.. Nothing helped like the EGR delete, now only issue I have is oil leak's, and crossover pipe is cracked, so new gaskets and headers and this thing will run forever
Old Mar 5, 2010 | 06:17 AM
  #200
San Martian's Avatar
I was plagued by a rough idle especially after coming to a stop after running on the highway. I suspected the EGR and after reading this thread and talking to a mechanic buddy I removed the little rubber hose and put on a little cap on the fitting. My runner idles smooth as silk today.
