Issue Going Between Park and Gear
#146
#152
#153
Just updating this, I was finally able to get a working TPS. Once I slap it on and get it dialed in correctly I will let you know if the truck still runs the same or if it's fixed.
#154
10.30.08
CEL is back on same code. Runs fine when cold but once it warms up and I am in any gear idle drops down and truck shakes a bit. It's not as bad as it use to be and like I mentioned before the TPS was bad I hate to say it but abe may be partially right. I am thinking it's an exhaust leak. How would I test for this to make 100% sure? Since the cat-back was replaced it must be at the headers something I cannot see either due to space or heat shields.
Thanks!
Thanks!
#156
Here is where I am going to look really stupid...if there is not a leak wouldn't doing that cause one (built up pressure?) or would the rag catch on fire?
#158
Update: 11/19
I replaced the o2 sensor with a Denso OEM. My CEL was gone for 3-4 days and the truck ran awesome, but then it came back. It seems that the truck runs fine but when the CEL hits the car starts to shake/idle like crap. I doubt it's an exhaust leak because it would run like crap/CEL right away, right? I am going to test the AFM next because that is really the only thing left? Any further ideas on what it could possibly be would help too.
#159
I am bringing this back from the dead because I am still having the same issue. Instead of you guys going through the thread I will write a cliff notes of what I have done.
- Replaced O2 for a Denso
- Swapped out AFM for a known good one
- Replaced TPS
- Cleaned TB
- Searched for a vacuum leak but did not find much
- Found an exhaust leak and fixed it
What I know:
- My EGR is blocked off and my TVV is broken and lost in the engine abyss. For now, I have a bolt stuck in there and I ran a hose from the charcoal canister to the plenum.
- My spark plug wires are Autolite, should I swap to NGK?
- Replaced TPS
- Cleaned TB
What I know:
