Issue Going Between Park and Gear
Old Aug 23, 2008 | 02:43 PM
  #141
abecedarian's Avatar
no. I think there's more wrong....
Old Aug 23, 2008 | 03:36 PM
  #142
BoostinChick's Avatar
I hope you are being sarcastic
Old Aug 23, 2008 | 03:54 PM
  #143
There's gotta be a vacuum leak somewhere in there.
Old Aug 23, 2008 | 04:22 PM
  #144
Old Aug 23, 2008 | 04:26 PM
  #145
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Awwww, that's not very ladylike.....hahahahaha!
Can't we all just get along.....?
Old Aug 23, 2008 | 04:30 PM
  #146
Who said I was anything like a lady? TPS being replaced soon just have to wait to get paid.
Old Aug 23, 2008 | 04:34 PM
  #147
Point taken sweetheart! And good job to you as well hun!
Old Aug 23, 2008 | 04:35 PM
  #148
maybe norbert can send you some of his street-walkin' money.
Old Aug 23, 2008 | 04:43 PM
  #149
Now that'll be the day!!!! Whose gonna pay him on the ho' stroll? Maybe to stay off the stroll.........
Old Aug 23, 2008 | 04:54 PM
  #150
just a 22re's Avatar
hey she knows i can get parts real cheap ive told her so nah nah nah nah
Old Aug 23, 2008 | 05:01 PM
  #151
But we were talkin bout your street walkin money/ gettin off the stroll money.....nothing bout gettin cheap parts....
Old Aug 23, 2008 | 07:06 PM
  #152
thook's Avatar
Auto Zone has genuine Denso units.....pretty cheap, comparitively. Atleast for the 22re they do. I guess you'd have to check for the 3vze.
Old Sep 18, 2008 | 05:51 AM
  #153
Just updating this, I was finally able to get a working TPS. Once I slap it on and get it dialed in correctly I will let you know if the truck still runs the same or if it's fixed.
Old Oct 30, 2008 | 10:03 AM
  #154
10.30.08
CEL is back on same code. Runs fine when cold but once it warms up and I am in any gear idle drops down and truck shakes a bit. It's not as bad as it use to be and like I mentioned before the TPS was bad I hate to say it but abe may be partially right. I am thinking it's an exhaust leak. How would I test for this to make 100% sure? Since the cat-back was replaced it must be at the headers something I cannot see either due to space or heat shields.
Thanks!
Old Oct 30, 2008 | 10:07 AM
  #155
you take a rag plug the hole at the back then let it run till you see the somke coming from the hole do do it to long though
Old Oct 30, 2008 | 10:44 AM
  #156
Here is where I am going to look really stupid...if there is not a leak wouldn't doing that cause one (built up pressure?) or would the rag catch on fire?
Old Oct 30, 2008 | 10:53 AM
  #157
if you've got a section of hose a few feet long, you can hold one end to your ear and move the other around the exhaust manifold, down pipe, etc and listen for the tick/puff.
Old Nov 19, 2008 | 10:53 AM
  #158
Update: 11/19
I replaced the o2 sensor with a Denso OEM. My CEL was gone for 3-4 days and the truck ran awesome, but then it came back. It seems that the truck runs fine but when the CEL hits the car starts to shake/idle like crap. I doubt it's an exhaust leak because it would run like crap/CEL right away, right? I am going to test the AFM next because that is really the only thing left? Any further ideas on what it could possibly be would help too.
Old Apr 28, 2009 | 06:44 AM
  #159
I am bringing this back from the dead because I am still having the same issue. Instead of you guys going through the thread I will write a cliff notes of what I have done.
- Replaced O2 for a Denso
- Swapped out AFM for a known good one
- Replaced TPS
- Cleaned TB
- Searched for a vacuum leak but did not find much
- Found an exhaust leak and fixed it
What I know:
- My EGR is blocked off and my TVV is broken and lost in the engine abyss. For now, I have a bolt stuck in there and I ran a hose from the charcoal canister to the plenum.
- My spark plug wires are Autolite, should I swap to NGK?
Old Apr 28, 2009 | 12:14 PM
  #160
Dealer wires. Both my 3.0's ran better with the stock wires from the dealer.
